search in folders and .gdb and rename featureclass
4755
01-18-2015 07:41 AM
PeterVersteeg
Hallo,
I have a database that are in file folders and in databases (gdb format). It looks a bit like this
Main File folder
                -filefolder “GIS”
                               -database.gdb B
                                               -featureclass J
                                               -featureclass K
                                               -featureclass L
                               -database.gdb C
                                               -featureclass J
                                               -featureclass K
                                               -featureclass L
                -Filefolder E
                               -database.gdb F
                                               -featureclass J
                                               -featureclass K
                                               -featureclass L
                               -database.mgb G
                                               -featureclass J
                                               -featureclass K
                                               -featureclass L
So the names of the folders and the gdb’s are unique but the featuresclass in each gdb have the same name (not the same factor).
What I want is a script that search for all featureclasses J, K and L and rename them. So far I have:
import arcpy
from arcpy import env
import os
# Set the workspace for the ListFeatureClass function
  1. arcpy.env.workspace = r"D: \GIS\ZONE1\ZONE1_007.gdb"
# Use the ListFeatureClasses function to return a list of all FC.
fclist = arcpy.ListFeatureClasses("*","ALL")
print fclist
# Rename FC
for fc in fclist:
    if fc == "TEKST_XX01P_point":
arcpy.Rename_management("TEKST_XX01P_point ", "P_XX01_house")
    elif fc == " TEKST_XX032_area ":
arcpy.Rename_management("TEKST_XX032_area", "A_XX032_forest")
print fclist
This works for only gdb set in my workspace. Can anyone help me with the code I need to search also the folders.  I was looking at the da.walk function but this is not working for me:
import arcpy
import os
workspace = 😧 \GIS "
feature_classes = []
for dirpath, dirnames, filenames in arcpy.da.Walk(workspace,
                                                  datatype="FeatureClass",
type="Polygon"):
    for filename in filenames:
feature_classes.append(os.path.join(dirpath, filename))
print filename
thank you greeting peter
XanderBakker
Esri Esteemed Contributor
Hi Peter,
First of all you should really use syntax highlighting, since it makes it easier to see where the error in code are:
Posting Code blocks in the new GeoNet
So you first part of the code, after deleting some redundant code (and spaces) and correcting some indentation would be:
import arcpy
arcpy.env.workspace = r"D:\GIS\ZONE1\ZONE1_007.gdb"
# Rename FC
for fc in fclist:
        arcpy.Rename_management("TEKST_XX01P_point", "P_XX01_house")
    elif fc == "TEKST_XX032_area":
The da functionality works if you have access to ArcGIS 10.1 SP1 or higher. If not you may want to read Recursive list feature classes | ArcPy Café. I assume you have access to the da module and what you should read is this post: Inventorying data: a new approach | ArcPy Café  (both by the ArcGIS Team Python).
A simple example is printing the name (full path) of the featureclass:
import os
import arcpy
def inventory_data(workspace, datatypes):
    Generates full path names under a catalog tree for all requested
    datatype(s).
    Parameters:
    workspace: string
        The top-level workspace that will be used.
    datatypes: string | list | tuple
        Keyword(s) representing the desired datatypes. A single
        datatype can be expressed as a string, otherwise use
        a list or tuple. See arcpy.da.Walk documentation
        for a full list.
    for path, path_names, data_names in arcpy.da.Walk(
            workspace, datatype=datatypes):
        for data_name in data_names:
            yield os.path.join(path, data_name)
for feature_class in inventory_data(r"c:\Forum", "FeatureClass"):
    print feature_class
From there you can include the logic for renaming the featureclass.
Kind regards, Xander
XanderBakker
Hi Peter,
import arcpy
# Rename FC
for fc in fclist:
import os
import arcpy
    datatype(s).
    Parameters:
    workspace: string
        for a full list.
    print feature_class
PeterVersteeg
Hi Xander,
First thank you for the syntax highlighting remark. I have the first part off my project working now:
import os
import arcpy
workspace = "D:\Documenten\GIS\Zone1\Zone1A"
datatypes = "Polygon"
    datatype(s).
    Parameters:
    workspace: string
        for a full list.
            workspace, datatype=datatypes, type="Polygon"):
for feature_class in inventory_data(workspace, "FeatureClass"):
    print feature_class
i put type in and arcpy.da.Walk also to give me more options. Going to work on the nameing part now.
again thank you.
greetings Peter
