Search Cursor Structure
1213
08-07-2013 06:29 AM
JamesSmith7
I am using a SearchCursor to return a value from a selected attribute field.  But, the cursor does not work or create an error.  The ValueGain filed is a Long field type that is has not been set to a string.  I am only using the SearchCursor to return a value in the tool dialog window.
arcpy.SelectLayerByAttribute_management(lyr, "NEW_SELECTION", whereClause) df.extent = lyr.getSelectedExtent() df.scale = df.scale*1.1 arcpy.AddMessage(str(whereClause))  cursor = arcpy.da.SearchCursor("Land", ["ValueGain"]) for row in cursor:  arcpy.AddMessage(str(ValueGain))  del row  del cursor
ArkadiuszMatoszka
When using arcpy.da.SearchCursor() each row is returned as list of values, correct call to get attribute value for row would be:
arcpy.SelectLayerByAttribute_management(lyr, "NEW_SELECTION", whereClause)  df.extent = lyr.getSelectedExtent()  df.scale = df.scale*1.1  arcpy.AddMessage(str(whereClause))   cursor = arcpy.da.SearchCursor("Land", ["ValueGain"])  for row in cursor:   arcpy.AddMessage(str(row[0])) # row[0] = first element of list that represents row  del row  del cursor
In case from your code:
ValueGain is unassigned variable, so you will get error.
Regards
Arek
ArkadiuszMatoszka
Regards
Arek
JamesSmith7
Thanks for the quick response.  Your suggestion worked.
ChrisSnyder
Honored Contributor
To be more precise, each row is returned as a Python tuple... which is similar to a Python list, but one that can't be rearanged/sorted (aka an imutable list).
In Python:
tupleExample = (1,2,3,4)
listExample = [1,2,3,4]
