Search by attributes tool
1016
05-15-2025 03:02 PM
2Quiker
I'm developing a script tool that allows users to select specific features on a map. The tool has three parameters:
Layer – The user selects the target map layer.
Layer Field – The user chooses a field within the selected layer.
Layer Field Attribute – The user selects an attribute value within the chosen field.
Once all parameters are set, the user runs the tool. However, despite receiving no errors, nothing gets selected on the map.
Script
import arcpy
class ToolValidator:
    def __init__(self):
        self.params = None
    def initializeParameters(self):
        return
    def updateParameters(self):
        # If the layer is selected, and it is a feature layer
        if self.params[0].value:
            layer_name = self.params[0].valueAsText
            try:
                fields = [f.name for f in arcpy.ListFields(layer_name)]
                if "PLAT_NAME" in fields:
                    self.params[1].value = "PLAT_NAME"  # Auto-populate the field name
                    # Get unique values from the PLAT_NAME field
                    values = set()
                    with arcpy.da.SearchCursor(layer_name, ["PLAT_NAME"]) as cursor:
                        for row in cursor:
                            if row[0]:
                                values.add(row[0])
                    self.params[2].filter.list = sorted(values)
                else:
                    self.params[1].value = None
                    self.params[2].filter.list = []
            except Exception as e:
        return
    def updateMessages(self):
        return
def main():
    # Parameters
    layer_name = arcpy.GetParameterAsText(0)   # Layer name to select from map
    field_name = arcpy.GetParameterAsText(1)   # Field to search (e.g., PLAT_NAME)
    acc_val = arcpy.GetParameterAsText(2)      # Attribute value (e.g., "BRIDGEWATER ESTATES #3")
    if not layer_name or not field_name or not acc_val:
        arcpy.AddError("Layer, field name, or search value is missing.")
        return
    # Access current project, map, and layout
    project = arcpy.mp.ArcGISProject("CURRENT")
    active_map = project.listMaps()[0]
    layout = project.listLayouts()[0]  # Layout is not used here, but included if needed
    # Get the target layer by name
    try:
        target_layer = active_map.listLayers(layer_name)[0]
    except IndexError:
        arcpy.AddError(f"Layer '{layer_name}' not found in the map.")
        return
    # Build where clause using input values directly (no escaping)
    expression = "{0} = '{1}'".format(field_name, acc_val)
    where_clause = str(expression)
    arcpy.AddMessage(f"Where clause: {where_clause}")
    # Perform the selection
    arcpy.management.SelectLayerByAttribute(target_layer, "NEW_SELECTION", where_clause)
    # Count and report results
    count = int(arcpy.management.GetCount(target_layer)[0])
    if count == 0:
        arcpy.AddWarning(f"No features found where {field_name} = '{acc_val}'.")
    else:
        arcpy.AddMessage(f"Selected {count} feature(s) where {field_name} = '{acc_val}'.")
AlfredBaldenweck
MVP Frequent Contributor
Gotta ask, why don't you just direct them to select by attribute? Is it because this tool is going to add the selection to the map?
Anyway, whenever you use select by attribute/location, you should ALWAYS assign it to a variable. This bites everyone at some point, and it's a common question here. So, Line 67 should be like
sel = arcpy.management.SelectLayerByAttribute(target_layer, "NEW_SELECTION", where_clause)
Then you can add it to the map, etc.
It might be something else, but at first glance, that's my guess.
HaydenWelch
MVP Regular Contributor
I flattened out your code a bit so it's easier to follow, it seems like your general flow is correct, I did add a call to arcpy.GetParameterInfo() in the ToolValidator initialization though.
import arcpy
    def __init__(self):
        self.params: list[arcpy.Parameter] = arcpy.GetParameterInfo()
    def initializeParameters(self): ...
        # No updates if the layer isn't selected yet
        if not self.params[0].value:
            return
        # Get LayerName and Fields
        # No options if 'PLAT_NAME' is not in the fields
        if "PLAT_NAME" not in fields:
            return
        values = {
            plat_name
            for plat_name, *_ in arcpy.da.SearchCursor(layer_name, ["PLAT_NAME"])
            if plat_name
        return
    def updateMessages(self): ...
def main():
    # Parameters
    if not all(layer_name, field_name, acc_val):
        return
    #layout = project.listLayouts()[0]  # Layout is not used here, but included if needed
    layer_match = active_map.listLayers(layer_name)
    target_layer = layer_match.pop() if layer_match else None
    if not target_layer:
        return
    where_clause = f"{field_name} = '{acc_val}'"
    try:
        arcpy.AddError(f"!!---Feature Selection Failed:---!!\n{e}")
        return
    count = sum(1 for _ in arcpy.da.SearchCursor(target_layer, ['OID@']))
    if not count:
        return
When you run the tool, are you getting any messages? If so which messages?
