Search and Update Cursor Need help.
2958
10
12-09-2013 06:21 AM
HectorChapa
I am trying to update a shapefile by using search and update cursor.
It searchs great on of the shapefile but when I try to update the other it only retrieves the first data.
I am providing my code so anyone could tell me how to modify it.
import arcpy  fc = "C:/Users/hchapa.LRGVDC911.000/Documents/ArcGIS/Default.gdb/Test_Shapefile_SpatialJoin" field = "parcel_1"   fc2 = "C:/GIS_DATA/Test_Shapefile.shp"   field2 = "parcel" value = [] cursor = arcpy.SearchCursor(fc) UpdateCursor = arcpy.UpdateCursor(fc2)    for row in cursor:     value = row.getValue(field)     for row2 in UpdateCursor:         row2.setValue(field2, value)         UpdateCursor.updateRow(row2)        print "Done"
the problem it only gets the first number but it doesnt iterate to the second number.
What am I doing wrong.
P.S I already try many other solutions nothing works.
I tried using a list.
JoshuaChisholm
Hello again Hector,
I think you're best switching to Wayne's code and adding a ".contains" line.
Wayne's Code (modified):
import arcpy
field = "parcel_1"
field2 = "parcel"
value = [] #You should remove this line. It's not needed.
# fetch the 1st row, for both search/update cursors
row = cursor.next()
row2 = UpdateCursor.next()
while row:
    if row.shape.touches(row2.shape):
        row2.setValue(field2, row.getValue(field))
    # advance both cursors to next row obj
    row = cursor.next()
del cursor, UpdateCursor
print "Done"
Although, a different process like Spatial Join may be a better approach for what you're doing.
