Scripting Tools: Specify file encoding
3437
01-19-2022 06:23 PM
AlfredBaldenweck
MVP Frequent Contributor
I'm making a scripting tool, and embedding the script in the tool when I'm done.
If I try to edit the script after doing this, I run into this message
The file's encoding is invalid for Python 3.x. IDLE will convert it to UTF-8. What is the current encoding of the file?
I haven't had this pop up at all before, despite doing this same thing with other script tools, including previous versions of this same tool.
The script is just a normal .py file, created in Notepad++
What does this message mean? What do I enter to let me edit it?
DanPatterson
MVP Esteemed Contributor
did you set the encoding in Notepad ++? and it didn't work?
then load the *.py into plain old Notepad, add the line to the top of the script, then try it in your ide
... sort of retired...
DanPatterson
Add this to the top of your scripts on the first line
# -*- coding: utf-8 -*-
AlfredBaldenweck
I just tried this and got the same error. Iʻm very confused.
DanPatterson
