Script working in Python window but not script tool
4658
13
01-29-2020 12:44 PM
GraceKeyes
I'm new to Python but am working with a very simple script to convert elevation units from meters to feet. It works in the Python window but not as a script tool. Below is my script.
import arcpy
arcpy.env.workspace = "C:\Users\keyesge\Desktop"
inputShp = "JunctionElev"
fieldName = "RASTERVALU"
expression = "!RASTERVALU! * 3.28084"
arcpy.CalculateField_management(inputShp, fieldName, expression,"PYTHON")
Any input is appreciated.
DanPatterson_Retired
fix the path problem first, it may fail without reporting the error if it is a script tool
And if it is a script tool, it would have no parameters is that what it shows when you run it?  That look more like a script you would run from the python window or the command line of another IDE like spyder or pycharm.
Also if you were running the script from outside of the builtin python window, nothing will get updated unless you close the table and reopen it.  If the table is open, it won't get refreshed.
GraceKeyes
 The results from running my script.
I fixed the file path. Again, I'm not getting any error messages and my table is closed when I run the script. Attached is a snip of my results window from running the script tool.
Grace Keyes
the above seems to be different than the script reported in the original
or is it the ElevationsTest.shp?
if it resides on the Desktop you will have issues.  Move the shapefile into a folder like r"C:\Temp" and skip the workspace and provide the full path to the file for the calculation
Can you fix or repost the script you are using that matches the above.
Also, since it is a shapefile, remove it from the project, then re-add it after the script has run
GraceKeyes
Thank you for all your input I will try this!
