script / toolbox for exporting table to a tab-delimited .txt file?
2892
6
02-15-2011 09:35 AM
RoyElis
I'm trying to export the data from an Attribute Table to a tab-delimited text file (.CSV would be ok too).  It's incredibly easy to do this through the menus in ArcMap: in the Table of Contents view, I open the Attribute Table, then go to the Table Options menu, choose "Export..." and then choose the "text" option when selecting the path for the output table. Done.
But I have 100s of tables to export, so I want to write a script to loop through them all.  I've looked in the existing Toolboxes in search of the right ArcPy command, but all I can find are tools that export to .dbf files.  Am I missing something or do I need to write something from scratch?
Thanks for any suggestions you can offer!
LoganPugh
LoganPugh
Take a look at Table to Table (Conversion).
LoganPugh
Try this script (Additional Conversion - Generic Tools) on the Script Tool Gallery: http://resources.arcgis.com/gallery/file/geoprocessing/details?entryID=95009B25-1422-2418-7FB5-B8638...
RoyElis
Thanks!  This looks perfect.  I'll give it a try and post the results.
RoyElis
Yup - it worked perfectly!  Thanks so much for your help!
VanessaS
I was wondering if you have upgraded this script for the v10 model builder?
Thanks in adavance.
curtvprice
Thanks in adavance.
Most script tools should work fine in Arc 10, including in Model Builder.
