Script database connect
1160
03-20-2012 04:09 AM
RenatoNogueira
Hi..
Is new programin in language python and problem connection database script arcsde.
Create script in arc catalog and export script to execute.
Script:
# processo_01.py
# Created on: 2012-01-13 11:30:03.00000
#   (generated by ArcGIS/ModelBuilder)
# Description:
# Import arcpy module
import arcpy
arcpy.env.workspace = "C:\\\connectionFiles\\GEO_DADOS.sde"
# Local variables:
gisvcc_dbo_INT_VW_SIG_IMOVEIS = "gisvcc.dbo.INT_VW_SIG_IMOVEIS"
gisvcc_GEO_DADOS_SIG_IMOVEIS = "gisvcc.GEO_DADOS.SIG_IMOVEIS"
# Process: Copy
arcpy.Copy_management(gisvcc_dbo_INT_VW_SIG_IMOVEIS, gisvcc_GEO_DADOS_SIG_IMOVEIS, "Table")
Before run script error:
C:\Python26\ArcGIS10.0>python.exe C:\Users\xxxx\Desktop\processo_01.
py
  File "C:\Users\xxxx\Desktop\processo_01.py", line 18, in <module>
OVEIS, "Table")
  File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\management.py", li
ne 3010, in Copy
    raise e
arcgisscripting.ExecuteError: ERROR 000258: Output C:\\connectionFiles\GEO_DADOS
.sde\gisvcc.GEO_DADOS.SIG_IMOVEIS already exists
Failed to execute (Copy).
which this error can be?!!?!?!?!?
MikeMacRae
It looks like your output in arcpy.Copy_management already exists. I would either delete it or use an overwrite statement to overwrite your output.
RenatoNogueira
Inside the tool it deletes and then recreates the information. Can you tell me which statement you use to delete first and then reconstruct the data?
MichaelVolz
Esteemed Contributor
renatognog:
Is your data being consumed by an ArcGIS Server service or ArcIMS service?  If it is I would recommend a truncate and append process that bypasses schema locks that are in place from the above mentioned services.  DeleteRows_Management followed by Append_Management
