Save mapx file using python
11919
15
09-20-2019 08:02 AM
JohnSawicki1
I am looking to save some but not all of my  Maps in an ArcGIS Pro document as templates. I know I can save the layers out using python but can't find a way to save the "mapx" file using python. I am saving these pieces tp put them into source control.
John
Yuriko
I am using ArcGIS Pro v2.5.1 and am unable to export a 'mapx' file form the console. When calling the method as described under the help documentation for 'Map'  with the line:
aprx = arcpy.mp.ArcGIS Project('CURRENT')
m = aprx.activeMap
m.exportToMAPX('Template.mapx')
I receive the following error:
File "<string>", line 3, in <module>
AttributeError: 'Map' object has no attribute 'exportToMAPX'
Any advice or redirection to resources would be much appreciated!
Tags (3)
Yuriko
Similarly, I receive this error when attempting to export a layout to a PAGX file.
AttributeError: 'Layout' object has no attribute 'exportToPAGX'
PaulCleverleyArup
I'm also getting "'Layout' object has no attribute 'exportToPAGX'"
Was there any resolution to this?
Paul
LaurensKusse_hhdelfland
This worked for me (ArcGIS Pro 2.9.5):
import arcpy
aprx = 'c:\\temp\\project.aprx'
folder = 'c:\\temp\\export'
p = arcpy.mp.ArcGISProject(aprx)
for m in p.listMaps():
    #export mapx file
    mapx_path = f'{folder}\\{m.name}.mapx'
    m.exportToMAPX(mapx_path)
for m in p.listLayouts():
    #export pagx file
    pagx_path = f'{folder}\\{m.name}.pagx'
    m.exportToPAGX(pagx_path)
MatthewMassey
This worked for me in the sense that I got a .mapx file, but the data sources for all the layers is not corrrect...they are all basically missing the name of the geodatabase in their source path. For example:
Name of source geodatabase: GEODATABSE.gdb
Correct path to source: PATH\GEODATABASE.gdb
Exported .mapx path to source: PATH\.gdb
That's very odd. I think you should contact support about that.
I could not reproduce it. When I open the MapX-file with Visual Studio Code, I see this in the json:
"dataConnection" : {
"type" : "CIMStandardDataConnection",
"workspaceConnectionString" : "DATABASE=X:\\GIS\\Projecten\\3D\\GemaalWestland\\FGDB\\Data.gdb",
"workspaceFactory" : "FileGDB",
"dataset" : "GemaalWestland",
"datasetType" : "esriDTFeatureClass"
