Save layer file to data source path
2126
07-02-2024 10:26 PM
FabioTuccini
Hello,
I'm trying to write a code to save the layer file (.lyrx) for each layer present in my project in the same folder of the data source.
At the moment I can only one by one, with the following code:
import arcpy
arcpy.mp.ArcGISProject('CURRENT')
arcpy.management.SaveToLayerFile('layer','output_path', 'RELATIVE')
But I wold like to create a iteration with all  layers in my project. It's important that each .lyrx will be saved in the data source path.
Someone can help please
FabioTuccini
Finally i found the solution. Maybe to someone can help, here the final code:
import arcpy
import os
aprx = arcpy.mp.ArcGISProject('CURRENT')
m = aprx.listMaps('Map') [0]
arcpy.env.overwriteOutput = True
for lyr in m.listLayers():
if lyr.isFeatureLayer:
arcpy.management.SaveToLayerFile(lyr,os.path.dirname(lyr.dataSource)+"\\"+lyr.name, 'RELATIVE')
simoxu
by MVP Alum
You are almost there, just put your code in the layer iteration:
m = aprx.listMaps("map name")[0]
    if !lyr.isGroupLayer:
        arcpy.management.SaveToLayerFile(lyr,'output_path', 'RELATIVE')
 Something like above, but I haven't tested code myself.
FabioTuccini
Thanks a lot, yes we are almost there but still missing somenthing.
I have modified the code as follow:
import arcpy
if lyr.isGroupLayer:
The  layer iteration is working but is replacing the outputfile with the same name.
I would like to get the output file name with the layer name and in the same folder of the source data. Is it possible?
FabioTuccini
OK, I'm very close!
I've modified the code as follow:
import arcpy
arcpy.management.SaveToLayerFile(lyr,lyr.dataSource + lyr.name, 'RELATIVE')
But I get the following error message:
File "<string>", line 6, in <module>
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\management.py", line 11180, in SaveToLayerFile
raise e
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\management.py", line 11177, in SaveToLayerFile
retval = convertArcObjectToPythonObject(gp.SaveToLayerFile_management(*gp_fixargs((in_layer, out_layer, is_relative_path, version), True)))
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 512, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000725: Output Layer: Dataset C:\Users\Fabio\Documents\ArcGIS\Projects\PRY002_WTL\03_Shape\Routes\Rerouting\VAB15_A.shpVAB15_A already exists.
Failed to execute (SaveToLayerFile).
FabioTuccini
import arcpy
import os
