RuntimeError: DescribeData: Method connectionProperties does not exist
3749
12-23-2013 01:03 AM
RavindraSingh
I want to get the connection Details from sdeConnection file.
<someName>.sde file
e.g. serverName, service, user, password etc.
for this I am writing following script.
import arcpy
desc = arcpy.Describe("C:\TEMP\sdeCon\connection.sde")
conPop = desc.connectionProperties()
@ above line it get error-- "RuntimeError: DescribeData: Method connectionProperties does not exist"
can some one please help, why so is happening, and how can I get the connection details from SdeFile.
NOTE:: Even I am getting the same issue in both ArcGIS 10 and 10.1
and I have set the path as C:\Python26\ArcGIS10.0 for ArcGIS 10 and C:\Python26\ArcGIS10.1 for ArcGIS 10.1
JakeSkinner
Esri Esteemed Contributor
Hi Ravindra,
You will want to place an 'r' in front of the path to your sde connection file.  Ex:
desc = arcpy.Describe(r"C:\TEMP\sdeCon\connection.sde")
Take a look at the following link for more information on setting paths:
http://resources.arcgis.com/en/help/main/10.2/index.html#//002z0000000r000000
