Runtime error Traceback - SelectLayerByAttribute
14034
13
04-07-2015 11:47 AM
SilvanStöckli
Hello
Every time I execute my python-script in the end it says
Runtime error  Traceback (most recent call last):   File "<string>", line 52, in <module>   File "c:\program files (x86)\arcgis\desktop10.3\arcpy\arcpy\management.py", line 7211, in SelectLayerByAttribute raise e ExecuteError: ERROR 000229: Cannot open Rest\Kartenausschnitte A3 mit Aussparung Legende. 1:2500 und 1:3000 Failed to execute (SelectLayerByAttribute).
So this is the "bad" part of my script. lyrkartenausschn is "Rest\Kartenausschnitte A3 mit Aussparung Legende. 1:2500 und 1:3000"
cursor = arcpy.da.SearchCursor(lyrkartenausschn, [seitenzkartenausschn])
    seitenliste = int(19)
    del seitenliste
    seitenliste = []
    for row in cursor:
        seitenliste.append(int(row[0]))
    print seitenliste
    for seite in seitenliste:
        for elm in arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT"):
            if elm.name == seitex:
                elm.text = str(seite)
                pfdausgabePDFeinzeln = pfadausgpdf[0:-4] +"_"+ str(seite) + ".pdf" #Path
        arcpy.SelectLayerByAttribute_management (lyrkartenausschn, "NEW_SELECTION", seitenzkartenausschn + " = " +  str(seite))
        mxd.dataDrivenPages.exportToPDF(pfdausgabePDFeinzeln, "SELECTED") #PDF Export
        mxd.dataDrivenPages.printPages(druckername, "SELECTED") #  Print
    mxdspeicher = ausgpdfmxd + "\\" + bewirtschafter + ".mxd"
    mxd.saveACopy(mxdspeicher)
    del row
    del cursor
    del seite
    del seitenliste
    del elm
    arcpy.RefreshActiveView()
There's a lot of things I'm doing bevore. So if I leave the "bad" part, it loops trough the whole script perfectly. If I add this part, the error appears.
I also tryed to add the line "arcpy.SelectLayerByAttribute_management (lyrkartenausschn, "CLEAR_SELECTION")" at the verry bottom, but then the same error appears for this line.
So what's wrong with the code? do I have to del something more? or "deactivate" data driven pages? (maybe it's a problem because it's still printing? but then how can I make it wait until it's finished?
thank you for your help!
XanderBakker
Esri Esteemed Contributor
This may be difficult to solve without the data and only part of the code. If the problem is caused by an access error of the layer contained in variable "lyrkartenausschn", you should have a look at how the layer is defined (this part is not included in the code posted).
I also came across this issue: 43104 - 000229: Cannot open  which indicates that if you have background processing switched on, it may cause this problem.
SilvanStöckli
Thank you so much!
I had backgroundprocessing turned on. So now I switched it off and it works.
I'm so happy
XanderBakker
Congratulation, glad it fixed it!
JoshuaBixby
MVP Esteemed Contributor
Great catch!  I reached a point where Background Processing was giving me enough headaches that I started moving more towards scripting ArcPy outside of ArcGIS Desktop.
