Run Particle tracking tool for a set of points
3580
12-20-2014 02:04 PM
GabrielBacca-Cortes
Hi All -
I started using Python for a couple of weeks now, but I am stuck with the subject problem.  I want to run either a CSV or a point FC providing a list of 'SourcePoints' required by the Particle Tracking tool. I've tried to set the code up in both ways, but don't know yet if it is accepted by the tool's parameters because I am getting another error regarding the outputTrack file, which is the TXT output file.  The name of this output file changes with respect to the point currently run through the tool. The error I am getting reads:
Failed to execute. Parameters are not valid.
ERROR 000885: Output particle track file:
C:\GIS\Track1\1_Orig\Track1.gdb\Tracklines\xy_1.txt's does not have a file extension.
Failed to execute (ParticleTrack).
When I print 'outTrackFile', the path and filename look ok, but the extension is not recognized though.
Any help trying to solve this issue is appreciate it !
thanks
Gabriel
import arcpy, os, csv
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/GIS/Track1/1_Orig/Track1.gdb/"
# Set local variables
outWorkspace = "C:/GIS/Track1/1_Orig/Track1.gdb/Tracklines/"
inDirectionRaster = "ragw_dir2"
inMagnitudeRaster = "ragw_mag2"
stepLength = 10
trackingTime = 10000000
# Check out the ArcGIS Spatial Analyst extension license
arcpy.CheckOutExtension("Spatial")
infile = open(r'C:\2_UWaterloo\10_ArcGIS\GWtoolset\LandBlocks\RA\input\SourcePts10.csv','r')
lines = []
for line in infile:
        lines.append(line.split(','))
infile.close()
#print lines
#field_names = ['point_x','point_y']
#coords = arcpy.da.SearchCursor(lines, field_names)
try:
        for line in lines[1:]:
                x = line[0]
                y = line[1]
                id = line[2]
                sourcePoint = arcpy.Point(x,y)
                #print sourcePoint
                # Output files in TXT and SHP formats for each x,y particle
                #outTrackFile = os.path.join(outWorkspace,"xy_" + str(id) + ".txt")
                outTrackFile = outWorkspace + "xy_" + id + ".txt"
                #print outTrackFile
                #outTrackPolylineFeatures = os.path.join(outWorkspace, "xy_" + str(id) + ".shp")
                outTrackPolylineFeatures = outWorkspace + "xy_" + id + ".shp"
                #print outTrackPolylineFeatures
                # Execute ParticleTrack
                ParticleTrack(inDirectionRaster, inMagnitudeRaster, sourcePoint,
                              outTrackFile, stepLength, trackingTime, outTrackPolylineFeatures)
except:
    print arcpy.GetMessages(2)
XanderBakker
Esri Esteemed Contributor
You are trying to create a text file in this location:
This is a dataset within your file geodatabase and that won't work. The other thing is you trying to create a shapefile inside you file geodatabase, which won't work either. It would be better to define the "outTrackFile" and "outTrackPolylineFeatures" as follows:
outTrackFile = os.path.join(folder, "xy_{0}.txt".format(id))
outTrackPolylineFeatures = os.path.join(ws, ds_name, "xy_{0}".format(id))
This will require defining another variable called folder that points to an existing folder where the text file should be created. I haven't looked closer to your code and obviously haven't tested it, but the code below might work for you:
import arcpy, os
folder = r"C:\GIS\Track1\1_Orig"
ws = r"C:\GIS\Track1\1_Orig\Track1.gdb"
ds_name = "Tracklines"
stepLength = 10
csv_file = r"C:\2_UWaterloo\10_ArcGIS\GWtoolset\LandBlocks\RA\input\SourcePts10.csv"
env.workspace = ws
i = 0
try:
    with open(csv_file ,'r') as infile:
        for line in infile:
            i += 1
            if i != 1:
                x = line.split(',')[0]
                y = line.split(',')[1]
                id = line.split(',')[2]
                sourcePoint = arcpy.Point(float(x),float(y))
    arcpy.CheckInExtension("Spatial")
except:
DanPatterson_Retired
did you forget the str(id) like you did in the commented out line?
XanderBakker
import arcpy, os
stepLength = 10
env.workspace = ws
i = 0
try:
        for line in infile:
            i += 1
            if i != 1:
except:
GabrielBacca-Cortes
Thanks Xander Bakker !
I incorporated your suggestions into my code, and decided to send the shapefile outside of the GDB as well, and work out nicely.  I tried your code and works as well... it is more 'elegant'
Thanks again, now I can have a beer !!
Gabriel
XanderBakker
Cheers! I'll have on too....
Could you mark the post as answered (there should be a button "Correct Answer" at each post, just click on the one corresponding to the post that answered your question).
