row_value = row[cursor.fields.index("LAST_UPDAT")] returns an integer
1327
06-27-2024 01:41 PM
SanchezNuñez
Good afternoon
I am trying to read this field that stores a date. It prints as an integer, I cannot convert it to a date.
Please advise
with arcpy.da.SearchCursor(feature_class, ["*"],where_clause ) as cursor:
for row in cursor:
rowdate_only = row_value.date()    -- This fails
DavidSolari
MVP Regular Contributor
Please make use of code sample formatting for Python code to avoid indent ambiguity, like so:
with arcpy.da.SearchCursor(feature_class, ["*"], where_clause) as cursor:
    for row in cursor:
        rowdate_only = row_value.date()  # This fails
What's the data type of "LAST_UPDAT"? If it's a string you'll need to use the this method, if it's an integer that represents a UNIX timestamp try something in this StackOverflow thread, and if it's a custom integer representation then parsing is non-trivial.
SanchezNuñez
Good morning @DavidSolari
Environment:
Field Name: USERID, Field Type: Integer
Field Name: LAST_UPDAT, Field Type: Date,  with value 1/31/2023 4:58:00.000 PM
SDE database in Ms SQS Server
Workstation and servers running in Windows
I am reading records from an SDE layer located in a Ms SQL Server database, and my goal is to update the same record on a AGOL hosted feature.   I am reading all records from SDE using arcpy.da.SearchCursor, then searching using USERID field in the hosted feature and comparing  dates using LAST_UPDAT field.
The compare dates does not work, something is missing.
My questions:
  • is the field date stored in the same way in AGOL and in SDE?  I am getting an integer for SDE and a data for AGOL
  • Do I need to do a conversion when I store the field LAST_UPDAT from SDE to AGOL?
JoshuaBixby
MVP Esteemed Contributor
Unfortunately, dates in cursors are handled differently between ArcGIS Desktop/ArcMap and ArcGIS Pro, so which software you are using makes a difference.  Which one are you using?
