Row objects in the Data Access module
3486
11
11-06-2012 11:15 AM
ChrisMathers
Can anyone explain the reasoning behind returning a row object as a tuple when using the Data Access module update cursor? I can understand it with a search cursor, you can dict(zip(cursor.fields,row)) and make a dictionary that lets you call the values by field name. I don't understand how I should be using this without counting to find the field index number in the tuple.  The help docs are not very clear on this topic. It seems like returning a dictionary would be easier for the users. I only just was given permission to update to 10.1 because sp1 is now  out so I may have missed this discussion at an earlier date. So as not to be entirely contrary, I do like the with-as usage for cursor's. That's pretty neat.
ChrisSnyder
Honored Contributor
BTW: I have heard that the .da cursors are similar to the way the ArcObjects cursors behave (with an index).
DavidWynne
Maybe there will be someone from the Arcpy team at SERUG this year I can bug about it :D. It was obviously a deliberate choice to make such a big change. Ill use your method for now Chris. tuple.index is a good solution.
Performance is the big reason.  Getting the row back in a tuple that you can pull values by index is a much faster approach than creating a row object and then have to make individual calls to get specific values.
The approach of forming a dictionary and then pulling values out from that is okay, but that is adding overhead just to enhance readability.  I would much rather just add code comment(s) if I need to clarify which field value is which.
-Dave
