Rounding decimals up using the field calculator
7963
11
02-23-2011 12:48 AM
EdelSødal_Pedersen
I'm new to python and couldn't find an answer elsewhere to this problem. And I guess it's not a big deal actually, but I just don't get it...
Code Block:
def tvol(a, b, area):
if (a >=2):
  return a*b/100
Expression:
tvol(!a!, !b!, !AREA!)
How do I get rounded values in the end, like VB would do. F. ex. 35.5 --> 36 and not 35, 35.4 --> 35.
Someone having an idea how to put this into the above script?
Thanks!
DanPatterson_Retired
to avoid integer division, one of the inputs must be cast as a float and the simplest way to do that in your case is to divide by 10.0 not 10
did you play around with python's round and/or int methods?
EdelSødal_Pedersen
I tried for example:
Code Block:
if (a >=2):
return round (a*b/100), 2)
The script works, but still the result is the same, because I think it's the standard of python to round that way.
I found some other infos arround that using ROUND_HALF_UP etc. or as described here:
http://docs.python.org/library/decimal.html
But I can't transfere the idea to the field calculator... :confused:
GerryGabrisch
try this...
    if (a >=2):
    return int(round(a*b/100))
EdelSødal_Pedersen
Thanks for the hint, but unfortunately I get the same result ... :confused:
MichaelStead
Never tried it, but it looks like some variation on ceiling may be available
http://docs.python.org/library/math.html
EdelSødal_Pedersen
Thanks for the link. math.ceil() really should do the trick!
It's also explained in section 5.4 here: http://docs.python.org/library/stdtypes.html
But this is really weird.
I've defined 3 new fields in the table just to make sure it's the right field type. So I have three fields AB and C, all are double.
The script for field c:
math.ceil ( !A! * !B! /10)
A=43, B=2 and I get C=8 (8.6, should result in 9)
Even if I just calculate !A! * !B! /10 within the field calculator, I do not even get decimals here (8.6, just returning 😎
So I'm wondering if there are some generell adjustments somewhere ... which are not correct 😞
EdelSødal_Pedersen
Thanks! 😄
Never would have figured out that it would be 10.0 instead of 10!
round(!A!* !B! /10.0) is giving the result I was looking for!
Thanks and a nice day to all of you!
ChrisGraves
Hi
I am experiencing the same issue where I need to round even numbers (ie 56.5) up and have tried the following script in the field calculator (using Python
parser) but it returns an error:
I'm not really up with Python so not sure what needs to be changed in the script.
Thanks in advance,
Chris
