Round to nearest 100th
13768
15
06-06-2013 07:57 AM
ChrisBrannin
I am a little confused about how to round a field to the nearest 100th. Would I use math.ceil() or the round()?
math.ceil([field]/100)*100
Does this only round down though?
Thanks
RhettZufelt
MVP Notable Contributor
Deleted my last post after re-reading.
However, it looks like you can use one for loop to replace all three that you are running.
might try something like:
import arcpy import os, math from arcpy import env   in_workspace = r"F:/Inventory_export_dev/testRnd" fcList = []    for dirpath, dirnames, filenames in arcpy.da.Walk(in_workspace, datatype="FeatureClass",type="All"):     for filename in filenames:         arcpy.AddField_management(os.path.join(dirpath, filename), fieldName, "SHORT", "", "", "", "", "NULLABLE")         arcpy.CalculateField_management(os.path.join(dirpath, filename), "SL_ELEV", "int(round( !ELEVATION!, -2))", "PYTHON")
No need to put the filenames in a list if all you are going to do is iterate through them again.  Just as well do the work on the first iteration.
Of course, this will errror out if any of the FC's in your in_workspace do not have the numeric ELEVATION field.
R_
MathewCoyle
Honored Contributor
math.ceil() always rounds up. math.floor() rounds down. round() rounds the the nearest integer or to a particular decimal place if the second parameter is specified.
round([field], 2)
ChrisBrannin
Thanks
How I mean to phrase this question is, how to round a number (say 11) to 0 instead of 100?
MathewCoyle
Honored Contributor
You would use a negative number for the second round() parameter of course. Use int() to ensure it returns an integer instead of float.
int(round([field], -2))
ChrisBrannin
That is the winner right there, thank you! I knew ther was a better way then to use math.ceil(). I really appreciate the help.
ChrisBrannin
How can I use this outside of arcmap? When I try, an error of "Invalid field [field]" appears.
I am trying to use it like this:
rndValue = "int(round(!ELEVATION!, -2))"
arcpy.CalculateField_management(elev, fieldName, rndValue, "PYTHON")
Thank you
MathewCoyle
Honored Contributor
That method works fine for me. Are you sure your field is the right type (long int)?
ChrisBrannin
I had no issue with it in arcmap attribute table field calculator. Just in IDLE... My code below:
import arcpy
import os, math
fcList = []
fieldName = "SL_ELEV"
        fcList.append(os.path.join(dirpath, filename))
for list in fcList:
    arcpy.AddField_management(list, fieldName, "SHORT", "", "", "", "", "NULLABLE")
print "Rounding ELEVATION field to SL_ELEV"
#Rounds values from [ELEVATION] to [SL_ELEV]
for elev in fcList:
am I missing something?
MathewCoyle
Honored Contributor
I would try printing out your elev value for each iteration of fcList to make sure it is what you expect.
RhettZufelt
Looks like you are trying to round the ELEVATION variable before you have set it to anything.
Need to either set it or extract it from the attributes first.
Also, both your for loops are working the same data, in one you assign it to list, in the other you assign to elev.  But, in both cases, you are still just itering through the values in fcList, so just as well do it in one swoop.
Think you are looking for something like this:
import arcpy
import os, math
fcList = []
for list in fcList:
    arcpy.CalculateField_management(list, "SL_ELEV", "int(round( !ELEVATION!, -2))", "PYTHON")
Haven't tested, but should go through each FC in your fcList add the field and populate it with the round value.
R_
