rotate split polylines python arcpy
6509
10
02-24-2020 12:36 PM
AdebayoIshola
I have converted polygon edges into polylines which I have also split at vertices. I am trying to rotate the polygon edges (segments) at angles which I have stored in a field in an attribute table.
The angles I have are for the polygon vertices. How do I proceed with rotating the segments -- preferably by scripting?
For instance, in the above image with a polygon, I need to move those 2 line segments until the angle between them are at right-angle and repeat same for all vertex/corners of the polygon.
EDIT: Providing additional context
AdebayoIshola
Hi Dan,
Thank you for your previous help and the tips you have provided but I need further help. Below is what I have:
  • A function that returns the maximum length of each of the rectangular polygons as a list. To be used as a reference edge/segment.
  • A function that returns the minimum length of each of the rectangular polygons as a list. To be used to construct length of a perpendicular edge.
  • A function that gets the coordinates of the endpoints of a polyline.
What would be an ideal approach to calculate the perpendicular offset points? Would I need to export/copy the longest edge of the polygon to a new FeatureClass before proceeding?
Any leads on a possible workflow would be very helpful.
