Retaining Field Names
896
11-05-2013 12:26 PM
TychoGranville
Just finished the Python web class, and I???m stuck....
I have a Feature Class with a table joined to it.
If I use ArcMap to manually export the FC to a shapefile (TOC --> right-click FC --> Data --> Export Data) I get a new file with the new fields all having the names of the previously joined table fields (so, Owner, Care_Of, etc)
If I use any type of Python command (FeatureClassToFeatureClass_conversion, Project_management, Clip_analysis) in that same MXD the field names change to the name of the table they came from, followed by a number (so, ParcelJo_1, ParcelJo_2, etc)
What command am I missing to keep the original field names?
Tycho
T__WayneWhitley
Honored Contributor
If I'm not mistaken you need to use unqualified field names...that's an environment setting, see the sample script in the web help:
Qualified Field Names (Environment setting)
Desktop » Geoprocessing » Environment settings
http://resources.arcgis.com/en/help/main/10.2/index.html#//001w00000008000000
The default value is 'True' so you have to set it to 'False' - here's an excerpt:
import arcpy arcpy.env.qualifiedFieldNames = False
Hope that helps.
Enjoy,
Wayne
T__WayneWhitley
Honored Contributor
Hope that helps.
Enjoy,
Wayne
TychoGranville
Awesome - that's exactly what  I needed!
Tycho
