Reprojecting an Extent object in a Python Toolbox
2042
12-18-2024 07:34 PM
LewisTrotter
Hello,
I am wondering how to reproject an arcpy.Extent object. I have a Python script toolboxes with a single GPExtent parameter. In the execute block, I have the following code:
ext = parameters[0].value
srs = arcpy.SpatialReference(4326)
ext.projectAs(srs)
When I run this, I get an error stating "RuntimeError: Object: CreateObject error creating spatial reference". Am I doing something wrong? Oddly, the above code runs fine in a notebook.
Thanks in advance!
DanPatterson
MVP Esteemed Contributor
Extent—ArcGIS Pro | Documentation
What is parameter 0?  use an AddMessage to report it.  Perhaps the extent object is non-existent or not in the correct form
... sort of retired...
LewisTrotter
Thanks Dan,
It is an Extent object, I can pluck the XMin, XMax et al. from it no problem. It also appears to have the correct .spatialReference.
DanPatterson
You might want to have a look at this link
Python Extent Calculations
it uses the extent object to make a geometry object, project it, then get the extent... seems to contradict the projectAs in the help though if the source and destination spatial references are known and correct
KristinBlier
Thanks! I ran into the same issue recently, and converting the extent to a geometry fixed it. Seems to be a python toolbox bug, because the Extent projectAs() works fine from a python shell. Never would've figured that out...
HaydenWelch
MVP Regular Contributor
You might need to assign a transformation, according to the docstring for Extent.projectAs():
If your projection requires a transformation, you can use ListTransformations  to get a list of valid transformations and pass those to the call:
from arcpy import Extent, SpatialReference, ListTransformations
ext: Extent = parameters[0].value
srs = SpatialReference(4326)
transformation: str = ListTransformations(ext.spatialReference, srs, extent=ext)[0]
ext.projectAs(srs, transformation_name=transformation)
