Report
3596
8
02-27-2017 11:47 AM
BrianLomas
Hey guys,
I working to get a report to run from a script and I can not figure out what I'm doing wrong. Any help you would have would be great. Thanks!
import arcpy
mxd = arcpy.mapping.MapDocument(r"G:\Public\Storm Projects\NPDES II Permit\Detention Basin Inspections\NEW_Detention Basins.mxd")
df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
lyr = arcpy.mapping.ListTableViews(mxd, "ArcGISSDE.SDE.Detention_Basin_Inspection", df)[0]
arcpy.SelectLayerByAttribute_management(lyr, "SUBSET_SELECTION", "[Date]= '12/1/2015'")
print ('Test')
arcpy.mapping.ExportReport(lyr,
                           r"M:\BrianLomas\RelationShipClassTest\DetentionBasin1.rlf",
                           r"C:\Users\blomas\Desktop\ReportTest.pdf",
                           "SELECTED")
del mxd
I currently get this error...
Executing: Report
Start Time: Mon Feb 27 13:47:32 2017
Running script Report...
Failed script Report...
File "M:\BrianLomas\Python Scripts\ImportantScripts\SelectReport.py", line 10, in <module>
"SELECTED")
File "c:\program files (x86)\arcgis\desktop10.3\arcpy\arcpy\utils.py", line 182, in fn_
return fn(*args, **kw)
File "c:\program files (x86)\arcgis\desktop10.3\arcpy\arcpy\mapping.py", line 532, in ExportReport
return report_source._arc_object.ExportReport(*gp_fixargs((report_layout_file, output_file, dataset_option, report_title, starting_page_number, page_range, report_definition_query, extent, field_map), True))
IOError: Could not write output file from report
Failed to execute (Report).
Failed at Mon Feb 27 13:47:34 2017 (Elapsed Time: 1.90 seconds)
BrianLomas
So, I finally got this bad boy to work. Thanks to both of you guys. Below is the script that worked but I had to run it as a python script with no parameters and in the foreground. On to figuring out the next few steps. Thanks again.
import arcpy
lyr = arcpy.mapping.TableView ("ArcGISSDE.SDE.Detention_Basin_Inspection")
                           r"C:\Users\blomas\Desktop\ProjectReport.pdf")
del mxd
MitchHolley1
MVP Alum
Is the "ArcGIDSDE.SDE.Detention_Basic_Inspection" a single layer in the MXD?
BrianLomas
yes, it's actually a related table if that makes a difference.
MitchHolley1
MVP Alum
Is there a reason you're using "SUBSET_SELECTION" selection method on that table?  Does the user select records prior to running this tool?
Also, I would make that layer a single variable in the tool.  Right now the variable 'lyr' is assigned to an arcpy function of ListTableViews.
BrianLomas
I'm trying to get it to just output a few pages because I haven't been able to get it to output anything. So, I was wondering if maybe it was an "out of memory" issue I was getting when I ran it from view\run report in arcmap. I was hoping to eventually build a script I can run on a handful of pages at a time because of the memory issue.
Right now, the selection is built into the script...
MitchHolley1
MVP Alum
Can you duplicate that selection in the Python GUI in that MXD without error?
JamesCrandall
MVP Alum
BrianLomas
Yea, I wondered that. I added that script to a toolbox and ran it from there as suggested but I get the same error.
BrianLomas
import arcpy
del mxd
