.replaceDataSource - Error Message?
1356
08-27-2020 03:56 AM
JohannesBierer
I've problems with .replaceDataSource. I get an error message running this script?
# -*- coding: cp1252 -*-
import arcpy, os
arcpy.env.overwriteOutput = True
mxd=arcpy.mapping.MapDocument(r"R:\SG-A\Karto\Bierer2020\WIBAS_Zentralisierung\ReplaceDataSource\Detail.mxd")
# Encoding der Standardausgabe herausfinden
stdout_encoding = sys.stdout.encoding or sys.getfilesystemencoding()
class ReplaceDataSource(object):
    def __init__(self):
        self.mxd = mxd
    def DataSourcesReplace(self):
        for lyr in arcpy.mapping.ListLayers(self.mxd, ""):
            if lyr.isServiceLayer == 1:
                print lyr.name + " is a WMS Layer"
            else:
                print lyr.name + " X " + lyr.dataSource
                dataSource = lyr.dataSource.encode(stdout_encoding)
                newDataSource = dataSource.replace("R:\\", "\\\\Client\\R$\\""")
                newDataSource1 = (os.path.dirname(newDataSource))
                print newDataSource1
                lyr.replaceDataSource(workspace_path = newDataSource1, workspace_type = "FILEGDB_WORKSPACE", dataset_name = lyr.name)
        mxd.saveACopy(r"R:\SG-A\Karto\Bierer2020\WIBAS_Zentralisierung\ReplaceDataSource\Detail_WIBAS.mxd")
if __name__ == '__main__':
    MyClass = ReplaceDataSource()
    MyClass.DataSourcesReplace()
Error Message:
Maßnahmenflaeche X R:\SG-A\Karto\Bierer2020\Wiedemann_Erlen_Metten_Gründelbachniederung_Auftragskarte\Bearbeitung.gdb\data\Massnahme
\\Client\R$\SG-A\Karto\Bierer2020\Wiedemann_Erlen_Metten_Gründelbachniederung_Auftragskarte\Bearbeitung.gdb\data
 ... line 36, in DataSourcesReplace
  File "C:\Program Files (x86)\ArcGIS\Desktop10.4\ArcPy\arcpy\utils.py", line 182, in fn_
    return fn(*args, **kw)
  File "C:\Program Files (x86)\ArcGIS\Desktop10.4\ArcPy\arcpy\_mapping.py", line 681, in replaceDataSource
    return convertArcObjectToPythonObject(self._arc_object.replaceDataSource(*gp_fixargs((workspace_path, workspace_type, dataset_name, validate), True)))
ValueError: Layer: Unexpected error
JohannesBierer
sorry wrong command - i wanted to do .findAndReplaceWorkspacePath
JohannesBierer
