replace characters label ArcMap
3008
7
11-01-2021 05:14 AM
TomasLooström
Hey!
I wish to use replace twice in the same field.
Attributes: >0980>Visy> GA: 8 must be labeled GA:8.
I use def FindLabel ([externid]): return [externid] .replace ('0980>Visy', ''), but fails to add code so that even the last > disappear.
Anyone know how to write it?
Best regards,
Tomas
Tags (1)
2 Solutions
by Anonymous User
Not applicable
Without getting to regex, you can chain them with what you need.
.replace('>0980>Visy>', '').replace('>0980>Fran>', '')
  If there are a lot, you can create a loop to iterate through all the variations from a list and replace them. Assuming there is a space there between the last > and GA:8,or you can find another way to parse out the part you want to replace.
for str in [str[0].split(' ')[0] for str in arcpy.da.SearchCursor(yourfc, [externid])]:
   [exernid].replace(str, '')
or index it as Jayanta provided.
[externid].split('>')[-1]
by Anonymous User
Not applicable
Is there some that contains spaces (> 0980> Visy>) and others that do not (>0980>Visy) in your field?  If that is the case, I'd suggest using
[externid].split('>')[-1].strip()
by Anonymous User
Not applicable
replace replaces the whatever string you put in the first parameter so you need to be explicit with what you want replaced.
TomasLooström
Thanks for the reply!
I missed writing that Visy can consist of different names, it varies and can then be Fran instead of Visy.
by Anonymous User
Not applicable
TomasLooström
When I use .replace ('> 0980> Visy>', '') .replace ('> 0980> Fran>', '') then> 0980>Visy is included in the labeling but last> disappears.
by Anonymous User
Not applicable
TomasLooström
Thanks, it works!
JayantaPoddar
Check if a similar script works
Parser: Python
(!FieldName!.split(' ',1)[1]).replace(' ','')
Think Location
