Repetitive Tasks: Save a copy of APRX, Rename Copied APRX, Query a layer, Set scale of map frame
1276
08-06-2024 02:13 PM
CiaraMarleneKeenan
Calling all Developers! I do NOT want to do something manually lol Or trying to do the least amount of repetitive tasks as possible.
I need a script that would allow me to
1. Save a copy of an APRX template
2. Rename the copied APRX x 50
3. Query a polygon layer based on a name field x 50
4. Set scale of map frame x ?
5. Pan to & center polygon feature in map frame x 50
Unfortunately, I am not able to use a map series for this particular project because there are too many different scales for the features to make the maps look nice. I need to make about 50 maps so the more I can do with python will be greatly appreciated.
TonyAlmeida
MVP Regular Contributor
Here is a little something to get you started.
Untested.
import arcpy
import os
template_aprx_path = r"C:\your\template.aprx"  # Path to your APRX template
output_folder = r"C:\output\folder"  # Folder to save the copies
polygon_layer_path = r"C:\path\to\your\polygon_layer"  # Path to your polygon layer
name_field = "Name"  # Field used for querying
map_frame_name = "Layers Map Frame"  # Name of the map frame to modify
scale = 50000  # Desired scale for the map frame
# Ensure output folder exists
if not os.path.exists(output_folder):
    os.makedirs(output_folder)
# Create copies of the APRX template and process each
for i in range(1, 51):  # Loop 50 times
    # Define the new APRX file path
    new_aprx_path = os.path.join(output_folder, f"Project_{i}.aprx")
    # Copy the APRX template to the new file
    arcpy.management.Copy(template_aprx_path, new_aprx_path)
    # Open the APRX file
    aprx = arcpy.mp.ArcGISProject(new_aprx_path)
    # Get the map
    map_obj = aprx.listMaps()[0]
    # Get the map frame
    map_frame = map_obj.listLayers(map_frame_name)[0]
    # Query the polygon layer and process each feature
    with arcpy.da.SearchCursor(polygon_layer_path, [name_field]) as cursor:
        for row in cursor:
            feature_name = row[0]
            # Select the polygon feature based on the name
            arcpy.management.SelectLayerByAttribute(polygon_layer_path, "NEW_SELECTION", f"{name_field} = '{feature_name}'")
            # Get the selected feature's extent
            selected_features = arcpy.management.MakeFeatureLayer(polygon_layer_path, "temp_lyr", f"{name_field} = '{feature_name}'")
            extent = arcpy.Describe(selected_features).extent
            # Zoom polygon feature in the map frame
            map_frame.camera.setExtent(extent)
            map_frame.camera.scale = scale
            # Save changes
            aprx.save()
    # Release the APRX object
    del aprx
print("Processing completed.")
CiaraMarleneKeenan
Hi Tony,
I am getting this error...
File "<string>", line 30, in <module>
IndexError: list index out of range
Also am I supposed to put quotes around the map name on line 27?
Thank you.
TonyAlmeida
The following code loops through the "CITY" field, processing each unique city. For each city, it creates a feature class in the geodatabase, zooms into that city's area, and generates a new .aprx file named after the city. I believe this code will do what you are asking. You may need to make adjustments to fit your specific requirements, hope it helps.
project.save()
import arcpy
import os
# Define paths
gdb_path = r"C:\your\template.gdb" # Path to your geodatabase location
polygon_layer_path = r"C:\your\template.gdb\layer" Path to your polygon layer
# Get the current project and map
project = arcpy.mp.ArcGISProject("CURRENT")
map = project.listMaps()[0]  # Adjust if necessary to select the correct map
lyt = project.listLayouts('Layout')[0]  # Adjust if necessary to select the correct layout, THIS IS SUPPER IMPORTANT, IF YO DON'T CHANGE IT TO MATCH YOURS,THE CODE WILL NOT CREATE THE APRX.
mf = lyt.listElements("MAPFRAME_ELEMENT", '*')[0]  # Get the first map frame element
# Make a feature layer from the feature class
arcpy.management.MakeFeatureLayer(polygon_layer_path, "city_limits_layer")
# Access the feature layer
city_limits_layer = "city_limits_layer"
# Get unique values from the CITY field
city_names = set()
with arcpy.da.SearchCursor(city_limits_layer, ["CITY"]) as cursor:
    for row in cursor:
        city_names.add(row[0])
# Loop through each unique city and create a feature class in the geodatabase
for city_name in city_names:
    # Create a feature layer for the city
    arcpy.management.MakeFeatureLayer(polygon_layer_path, "temp_city_layer", f"\"CITY\" = '{city_name}'")
    # Define the path for the new feature class in the geodatabase
    city_feature_class = os.path.join(gdb_path, f"{city_name.replace(' ', '_')}_fc")
    # Copy the feature layer to the geodatabase
    arcpy.management.CopyFeatures("temp_city_layer", city_feature_class)
    # Add the feature class to the map
    map.addDataFromPath(city_feature_class)
    # Get the new layer from the map
    new_layer = map.listLayers(f"{city_name.replace(' ', '_')}_fc")[0]
    # Get extent using arcpy.Describe()
    desc = arcpy.Describe(new_layer)
    ext = desc.extent
    # Zoom to the extent of the layer
    mf.camera.setExtent(ext)
    # Set the scale to 1:24,000
    mf.camera.scale = 24000
    # Create a new project for each city
    new_project_path = os.path.join(r"C:|Tenp\CityLimits", f"{city_name.replace(' ', '_')}.aprx") # Folder to save the copies
    new_project = arcpy.mp.ArcGISProject("CURRENT")
    new_project.saveACopy(new_project_path)
# Save the original project (optional)
#project.save()
