Removing/Replacing specific characters from a field
4932
10
10-31-2018 03:54 PM
GIS_geek
I am trying to remove specific characters from a field called CCTV_SLID.  The field I am working with looks like this CLMH123W456MH123W455, STMH123W457, SIMH123W458, SYMH123W459.  I am trying to remove the prefixes which are CL, ST, SI, and SY.  I have the following script and get a IOError: "C" does not exist error. Any help would be appreciated. Thanks.
# Remove prefix from CCTV_SLID
fcLst = "C:/Desktop/CCTV.gdb/GravityMain"
for fc in fcLst:
    fieldList = [f.name for f in arcpy.ListFields(fc) if f.type == "String"]
    if fieldList:
        with arcpy.da.UpdateCurson(fc, fieldList) as cursor:
            for row in cursor:
                for i in range(len(fieldList)):
                    row = row.replace("CL"," ")
                    cursor.updateRow(row)
curtvprice
Here's my preferred approach (which Joe mentioned).
In Python some times it is easier to just let an error happen instead of coding a check for every possible thing that can go wrong (in your case, that the text field has a null value).
I also fixed this so it will only remove the prefix, that is, your prefix must be the first two chars of the text field value.
import arcpy
print("Replace and remove prefix from any and all text fields.")
fcLst = ["C:/Desktop/CCTV.gdb/GravityMain"]
for fc in fcLst:
    if fieldList:
        with arcpy.da.UpdateCursor(fc, fieldList) as cursor:
            for row in cursor:
                    try:
                        if row[i][:2] in ["CL", "ST", "SI","SY"]:
                            row[i] = row[i][2:]
                    except:
                        pass
DanPatterson_Retired
/blogs/dan_patterson/2016/08/14/script-formatting  would really help because line numbers can be referred to
GIS_geek
import arcpy
print("Replace and remove prefix from CCTV_SLID.")
for fc in fcLst:
    if fieldList:
            for row in cursor:
                    row[i] = row[i].replace("CL"," ")
curtvprice
import arcpy
for fc in fcLst:
    if fieldList:
            for row in cursor:
                    try:
                            row[i] = row[i][2:]
                    except:
                        pass
JoshuaBixby
MVP Esteemed Contributor
I suggest out-denting your cursor update call, Line #13, by one level.  You can wait until you have updated the entire row before committing it.
curtvprice
Joshua, you are so right. Unnecessarily calling an update could massively slow things down. Here's a fix that outdents it even more so only one update would be called, and only if a change was made:
import arcpy
for fc in fcLst:
    if fieldList:
            for row in cursor:
                rowmod = False
                    try:
                            row[i] = row[i][2:]
                            rowmod = True
                    except:
                        pass
                if rowmod:
for fc in fcLst:
    print(fc)
C
D
e
s
...... snip .......
you don't have a list for the fcList
you want
for fc in fcLst:
    print(fc)
GIS_geek
Dan,
I updated the script and I get the following error
      row = row.replace("CL","")
AttributeError: 'NoneType' object has no attribute 'replace'
JoeBorgione
None means your value for row is null.  You'll need to 'trap' for that condition with an if conditional or a try/except block.
That should just about do it....
if row is not None:
    Do the work here
if row[i] not in (None, "", "anything else you want to check for"):
    Do good stuff here
