Removing empty feature classes from a geodatabase
7216
02-10-2011 04:15 PM
JustinOdell
Does anybody know of a script that exists to do this?
I have come across this link where some people have had success, others not.
I tried it myself, but no luck.
StefanHaglund1
Hi Hydronaut,
What specific problem do you have with the code in the link?
I believe that with some of the changes suggested in the comments in the link you sent, this should work. I was removing empty layers from mxd�??s with a similar method. What I found (in v.10) is that you need to make an integer of the results object from GetCount_management.
So if you look at comment #5 in the link, which says:
result = arcpy.GetCount_management(fc)
print result
if result == 0:
print fc + �?� is empty.�?�
arcpy.delete_management(fc)
Change that to
result =  arcpy.GetCount_management(lyr)
count = int(result.getOutput(0))
if count == 0:
 arcpy.mapping.RemoveLayer(df, lyr)
 print "Removing " + lyr
else:
 print "Keeping " + lyr
In the code above, substitute arcpy.mapping.RemoveLayer for arcpy.Delete_management.
Also, you might need to handle FC's inside feature datasets like the first comment suggests.
StefanHaglund1
Adding to my post above, there's an explanation in the help why you need to handle the result object.
Have a look here: http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//002z0000000n000000.htm
In the note under the "Getting results from a tool" heading, it says:
The result object's getOutput method returns a Unicode string from result objects that have output values. This is an important consideration when running a tool such as GetCount, which provides a count of records in a table, or CalculateDefaultClusterTolerance, which provides a cluster tolerance value. To convert the value to the expected type, it will have to be converted from a unicode string using built-in Python functions such as int() or float().
JustinOdell
This is the code I have.  I've never taken a Python scripting course, so I'm a bit of a noob when it comes to programming.
The problem I find when running the script in IDLE, is that it gets stuck in the while loop, and (I think) tries to keep removing the same feature dataset.
## Delete Empty Feature Classes from Multiple Geodatabases
## This script loops through all geodatabases within a directory
## and removes empty featureclasses from each geodatabase.
## User must hardcode directory. Run this script in IDLE.
## Python Version 2.4
# Create the Geoprocessor object
import arcgisscripting, os, sys, string
gp = arcgisscripting.create()
# Load required toolboxes�?�
gp.AddToolbox("C:\\Program Files\\ArcGIS\\ArcToolbox\\Toolboxes\\Conversion Tools.tbx")
# Set workspace
gp.workspace = "L:\\Justin\\00_jobs\\Python_Scripting_Test\\"
# list personal geodatabases in the current workspace
listmdb = gp.listworkspaces("*", "FileGDB")
mdb = listmdb.next()
# loop through the personal geodatabases
while mdb:
    print mdb
    gp.workspace = mdb
    # list feature datasets in personal geodatabase
    listfdset=gp.listdatasets()
    fdset=listfdset.next()
    # loop through feature dataset
    while fdset:
        print "fdset: ", fdset
        if not fdset == None:
            gp.workspace = mdb + "\\" + fdset
    # list feature classes in the personal geodatabase
        fcs = gp.listfeatureclasses()
        fcs.reset()
        fc = fcs.next()
    # loop through the featureclasses
    while fc:
        print fc, gp.GetCount_management(fc)
        # if the feature class table has no records, delete the featureclass
        if gp.GetCount_management(fc) == 0:
            gp.Delete_management(fc)
            print fc + "deleted from" + mdb
        fc = fcs.next()
Any help is greatly appreciated.
NiklasNorrthon
My advice is: Don't loop with while! (Not in arcpy, and not in previous versions of arcgis either). The ArcGIS sample code is written by someone not knowing python.
arcpy version:
listmdb = arcpy.ListWorkspaces('*', 'FileGDB')
for mdb in listmdb:
    print mdb
    # same logic as above
    # change inner loops to for loops too
    # don't call next, since it's done behind the scene with the for loop
ArcGIS 9.2 version:
listmdb = gp.ListWorkspaces('*', 'FileGDB')
for mdb in iter(listmdb.next, None): # Note: no function parantheses following next
    print mdb
JustinOdell
Hmm... I seem to be making less progress than with the while loops.  I will get myself in to do a Python course, but as it stands I am struggling to get the code to do what I want it to.
Is anybody able to write or test the code and fix it so that it deletes empty feature classes AND empty feature datasets from a geodatabase?  I would be very thankful.
