RemoveLayer not working
1381
02-13-2020 11:18 AM
by Anonymous User
Not applicable
I've tried a few different approach to remove a layer from the TOC, but none so far works.
The ultimate goal is to add the layer to a group, then remove it from the TOC
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd)[0]
addLayer =arcpy.mapping.Layer("C:\TEMP\ArcGIS\HighLake2004\Group.lyr")
arcpy.mapping.AddLayer(df,addLayer)
tgl=arcpy.mapping.ListLayers(mxd, "Group", df)[0]
lyr = arcpy.mapping.Layer(OutPutLayer)
arcpy.mapping.AddLayer(df, lyr)
arcpy.mapping.AddLayerToGroup(df,tgl,lyr)
arcpy.mapping.RemoveLayer(df,lyr)
arcpy.RefreshTOC()
Then I have another question, even if I remove them after in ArcGIS, they are still available in my script parameters...
DanPatterson_Retired
where is this defined? OutPutLayer
Also, code formatting will provide line numbers to your code
/blogs/dan_patterson/2016/08/14/script-formatting
by Anonymous User
Not applicable
InputGrid= arcpy.GetParameterAsText(0)
OutPutGrid = arcpy.GetParameterAsText(1)
Azimut = arcpy.GetParameterAsText(2)
OutPutLayer =OutPutGrid + "_grd"
by Anonymous User
Not applicable
Hi Dan, Here is th full code :
# -*- coding: utf-8 -*-
# PYFromModel.py
# Created on: 2020-02-10 13:20:12.00000
#   (generated by ArcGIS/ModelBuilder)
# Usage: PYFromModel <co_27b_res56k_nad83_grd> <tiltd_27a> <res56k_27a_sh> <Azimuth>
# Description:
# Import arcpy module
import arcpy
# Script arguments
##if InputGrid == '#' or not co_27b_res56k_nad83_grd:
##    co_27b_res56k_nad83_grd = "co-27b_res56k-nad83.grd" # provide a default value if unspecified
print(InputGrid)
arcpy.AddMessage(InputGrid)
arcpy.env.workspace = "C:\TEMP\ArcGIS\HighLake2004"
sr = arcpy.SpatialReference("NAD 1983 UTM Zone 12N")
#copy raster
#tempEnvironment0 = arcpy.env.cartographicCoordinateSystem
arcpy.env.cartographicCoordinateSystem = "PROJCS['NAD_1983_UTM_Zone_12N',\
                                            GEOGCS['GCS_North_American_1983',\
                                            DATUM['D_North_American_1983',\
                                            SPHEROID['GRS_1980',6378137.0,298.257222101]],\
                                            PRIMEM['Greenwich',0.0],\
                                            UNIT['Degree',0.0174532925199433]],\
                                            PROJECTION['Transverse_Mercator'],\
                                            PARAMETER['False_Easting',500000.0],\
                                            PARAMETER['False_Northing',0.0],\
                                            PARAMETER['Central_Meridian',-111.0],\
                                            PARAMETER['Scale_Factor',0.9996],\
                                            PARAMETER['Latitude_Of_Origin',0.0],\
                                            UNIT['Meter',1.0]]"
arcpy.CopyRaster_management(InputGrid, OutPutGrid)
arcpy.DefineProjection_management(OutPutGrid,sr)
#arcpy.env.cartographicCoordinateSystem = tempEnvironment0
arcpy.MakeRasterLayer_management(OutPutGrid, OutPutLayer)
arcpy.gp.HillShade_sa(OutPutGrid, OutPutGrid + "_SH", 0, "45", "NO_SHADOWS", "1")
arcpy.MakeRasterLayer_management(OutPutGrid +"_sh",OutPutLayer + "_SH")
for lyrs in arcpy.mapping.ListLayers(mxd,"*",df):
    if lyrs.name == 'Group':
        lyrs.name=OutPutGrid
##arcpy.mapping.AddLayerToGroup(df,OutPutGrid,lyr)
#LayersToRemove =[ lyr]
arcpy.RefreshTOC()
lyr = arcpy.mapping.Layer(OutPutLayer + "_SH")
if lyr.supports("TRANSPARENCY"):
        lyr.transparency = 50
arcpy.mapping.AddLayerToGroup(df,tgl,lyr,"TOP")
arcpy.RefreshTOC()
#LayersToRemove.append( lyr)
#for LayerList in arcpy.mapping.ListLayers(mxd,"*",df):
#    if LayerList.name in (LayersToRemove):
#        arcpy.mapping.RemoveLayer(df,LayerList)
#        arcpy.RefreshTOC()
##'arcpy.mapping.AddLayerToGroup(df,OutPutGrid,lyr)
#arcpy.RefreshTOC()
#arcpy.RefreshActiveView()
