removeLayer() error
1332
12-22-2022 01:30 PM
ZacharyStanley
Hello-
I'm simply trying to remove a layer from an aprx using arcpy and am getting an error related to the save() function. Below is code and resulting error:
# import modules
import arcpy
from arcpy import mp
import os
# remove temporary layers from the map
aprx = mp.ArcGISProject(r"N:\Projects\ElectionsOffice\VoterAddresses\VoterAddresses.aprx")
aprxMap = aprx.listMaps()[0]
for lyr in aprxMap.listLayers():
    if lyr.name == 'sgmj_2872_Layer2':
        aprxMap.removeLayer(lyr)
aprx.save()
OSError                                   Traceback (most recent call last)
In  [40]:
Line 7:     aprx.save()
File C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\_mp.py, in save:
Line 308:   return convertArcObjectToPythonObject(self._arc_object.save(*gp_fixargs((), True)))
OSError: N:\Projects\ElectionsOffice\VoterAddresses\VoterAddresses.aprx
DanPatterson
MVP Esteemed Contributor
related information
Solved: removeLayer require some kind of refresh? - Esri Community
I would throw in a print statement or two since I suspect you have no aprxMap or perhaps layers to process.
If all seems fine try a saveAs instead of save, using a different output name to ensure that the process can complete with some form of "save" option
... sort of retired...
DonMorrison1
Maybe you (or somebody else) has the project open in ArcGIS Pro?
