Remove ordinals in an address
1422
07-28-2023 09:13 AM
Michael_Kleinman
Hi, I'm using Pro 3.1.2. I have a database with street names that I need to remove all the ordinals from. So "SE 1ST ST" would just be "SE 1 ST"; "SE 44TH ST" would become SE 44 ST" etc. I need to remove the "ST" when it signifies first (1ST) but not when it signifies Street (also ST). So only after a number. The same with "TH" in "44TH", but not in "NORTH." I'm having trouble writing something that will catch and remove the ordinals only after a number 0-9.
I've tried to use this without any luck
(?<=[0-9])(?:st|nd|rd|th)
Does anyone have any suggestions? Thanks in advance.
by Anonymous User
Not applicable
https://regex101.com/  make sure you select python on the left, copy some strings into the test string and build away at the top.
(\d+ST)|(\d+ND)|(\d+RD)|(\d+TH)
captures the ##ST ##ND ##RD ##TH
(?<=\d)ST|TH|ND|RD
captures just the ST, ND, TH, RD
1st Alternative
(?<=\d)ST
Positive Lookbehind (?<=\d)
Assert that the Regex below matches \d matches a digit (equivalent to [0-9])
ST matches the characters ST literally (case sensitive)
2nd Alternative
TH matches the characters TH literally (case sensitive)
3rd Alternative
ND matches the characters ND literally (case sensitive)
4th Alternative
RD matches the characters RD literally (case sensitive)
by Anonymous User
Not applicable
Here it is in action-
addrs = ['SE 1ST ST', 'SE 2ND ST', 'SE 03RD ST', 'SE 15TH ST']
comp = re.compile(r"(?<=\d)ST|TH|ND|RD")
for a in addrs:
    match = comp.search(a)
    f = comp.sub("", a)
    print(f'Changed {match.group(0)} : {a} : {f}')
