Remove join
9651
10
08-20-2012 03:24 AM
Bart-JanSchoenmakers
Hi all,
I'm having a problem removing a join with python code (ArcGIS 10.0).
With a python script I'm doing a spatial SORT for a number of polygons which fall within a certain number of regions. Within a function I do the following:
  • Create a temporary featureclass as result from the Spatial sort
  • Put the value of the ObjectID in a new field
  • Add a join between the input layer and the temporary FC
  • Calculate the value of the sorted objected for the input FC
  • Remove the join
This is the code of the python function.
def spatialsort (inlayer, outfc, nutsvalue):
    # (temp FC, spatial sort, add field, calc OID, atribuir valor join, ...)
    # temp fc Nome
    tempfcnome = tempfd + "\\SORT" + nutsvalue
    tempfcnome2 = "SORT" + nutsvalue
    if gp.Exists(tempfcnome):
        gp.Delete_management(tempfcnome, "")
    gp.Sort_management(inlayer, tempfcnome, "SHAPE ASCENDING", "PEANO")
    # Adicionar campo SORT
    gp.AddField_management(tempfcnome, "SORT_TEMP_ID", "LONG", 6)
    # Calcular campo
    # nao seria necessario pode fazer o calculate a partir OBJECTID original
    gp.CalculateField_management(tempfcnome, "SORT_TEMP_ID", "!OBJECTID!","PYTHON")
    # Adicionar Join
    joinField = "GRD_NEWID"
    fieldList = ["SORT_TEMP_ID"] # OBJECTID
    # criar table view (alternative to using featurelayer):
    theDesc = gp.Describe(inlayer)
    gp.MakeTableView_management (theDesc.catalogPath, "temptableview")
    theDesc = gp.Describe(tempfcnome)
    gp.MakeTableView_management (theDesc.catalogPath, "temptableview2")
    # Using tableviews
    gp.JoinField_management ("temptableview", joinField, "temptableview2", joinField, fieldList) # tempfcnome
Everything works fine except the last step. I tried to remove the join using as input:
Using the fullname of the layer:
[INDENT]arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid. The value cannot be a feature class[/INDENT]Using only the basename:
[INDENT]ERROR 000732: Layer Name or Table View: Dataset TEST2_GRID_1KM_CONT does not exist or is not supported[/INDENT]Using the name of layer (this case gridlayer):
[INDENT]arcgisscripting.ExecuteError: ERROR 000229: Cannot open gridlayer[/INDENT]
Using tableviews as input, error:
[INDENT]    gp.RemoveJoin_management ("temptableview",  "temptableview2")
arcgisscripting.ExecuteError: ERROR 000229: Cannot open temptableview[/INDENT]
I checked the following topic http://forums.arcgis.com/threads/13163-arcgis-10-is-there-a-way-to-remove-all-joins-with-python, but this didn�??t offer any solution.
Does anyone knows what I�??m doing wrong? Any suggestions for alternative ways?
Thank you,
Bart Schoenmakers
Thanks Caleb for the answer. It works using the AddJoin command.
The following code works for me:
gp.AddJoin_management (layjoin, joinField, tempfcnome, joinField)
# Removing join:
 gp.RemoveJoin_management (layjoin, theDesc.Name)
Bart
