Remove first 2 characters using if statement
3591
11
08-09-2013 02:54 PM
AmyKlug
Hi, I would like to have this code remove and XY or RR (if they are the first 2 characters) in a field with values
XY2365541
RR1247884
8965445
would be:
2365541
1247884
8965445
Writing a query is giving me trouble. I was trying this code with a search cursor, getvalue and if elif statement...but no luck
import arcpy Feature_Class_Name = arcpy.GetParameterAsText(0) Output_Features = arcpy.GetParameterAsText(1) arcpy.env.workspace = r"H:/TestMDB.gdb/XY_1"  cursor = arcpy.da.UpdateCursor(Feature_Class_Name, ["NM"]) for row in cursor:     cursor.updateRow([row[0][2:]]) del fc
by Anonymous User
Not applicable
If you just want to extract the digits and ignore everything else, why not make it simple:
>>> with arcpy.da.UpdateCursor("Stream_points",['TEST']) as rows: ...     for row in rows: ...         v = row[0] ...         row[0] = ''.join(i for i in v if i.isdigit()) ...         rows.updateRow(row) ...          >>>
This will yield:
2365541
1247884
8965445
EDIT: I should clarify that this removes ALL text and leaves ONLY the digits.  If you want to keep other prefixes use Dan or Wayne's method.
DanPatterson_Retired
is pseudo code
avalue (a row value in string format)
prefix = ["XY", "RR"]
if avalue[0:2] in prefix:
   avalue = avalue[2:]
print avalue
AmyKlug
is pseudo code
   avalue = avalue[2:]
print avalue
not really sure what to do here
T__WayneWhitley
Honored Contributor
Dan said you "here's your pseudocode", so you have to test something out -- this line is wrong:
...believe you have to set the row field val 1st then update the row...as in something like:
row[0] = row[0][2:]
cursor.updateRow(row)
Try that substitution...actually, I think you specified you wanted to test for the 1st 2 char, then substitute something else - so you'll need an 'if' statement, plenty of examples in the web help.  Make a copy of your fc, and start experimenting, following the above for starters.
Enjoy,
Wayne
AmyKlug
row[0] = row[0][2:]
Enjoy,
Wayne
I will be more specific......
is pseudo code
avalue = avalue[2:]
print avalue
I read this as.......if row[0:2] in ["XY", "RR].........this makes no sense to me. Row[0:2] is a row value such as XY885442554 and nothing I have tried recognizes ["XY, "RR"]. Do I need to also use a search cursor?
Within a cursor of some form (insert possibly in your case), if the first two characters ( [0:2] ) are "XY" or "RR" are found within the offending list ["XY", "RR"], substitute/update your field/row with the value with those values removed.
It is hard to debug someone else's code unless you have field calculator syntax that works before you move on to automating the process to include multiple cases.  Try to simply the operation by performing single steps at a time (eg.  strip off "XY" if it is contained within a field) then move onto the next selection finding fields that begin with "RR" and stripping those off.  If this is a one-off deal you are done...if this is daily, then generate a field calculator expression which covers all cases.   I often find the former faster than the latter and I have been coding for years.
T__WayneWhitley
Honored Contributor
Yes, maybe the 'stumbling block' here is the isolation of text to trim, or at least selecting those for some kind of conditional 'slicing' or text formatting, whatever -- so I have found the best way to grow more accustomed to how Python handles string handling is to test something interactively, say in IDLE or ArcMap's python window.  You can even test expressions in the field calculator - as long as you have saved a copy of your data, you can practice, no matter really if it succeeds/fails or even crashes/freezes ArcMap, think we've all done that...restart and try again.
Having said that, check out this behavior using IDLE:
>>> bunchOfValues = ('XY885442554', 'TY3485694873', 'RR473892711')
>>> print bunchOfValues
>>> for eachValue in bunchOfValues:
 print eachValue
XY885442554
TY3485694873
RR473892711
 if eachValue[0:2] in ['XY', 'RR']:
  print eachValue[2:]
 else:
  print eachValue
885442554
TY3485694873
473892711
...still want more, see this, the skinny:
http://stackoverflow.com/questions/509211/the-python-slice-notation
AmyKlug
Thanks Dan and Wayne.....that really helped. Here is the final code:
>>> import arcpy
>>> fc = r"H:/Test.gdb/NameTest"
>>> cursor = arcpy.da.UpdateCursor(fc, ["NM"])
>>> for row in cursor:
...     row = row[0]
...     if row[:2] == "XY":
...         cursor.updateRow([row[2:]])
...     elif row[:2] == "RR":
...     else:
...         print "Name field is alread up-to-date"
>>>> del fc, cursor
To emphasize the useage of the "in" list operand consider the following:
>>> bunchOfValues = ['XY885442554', 'TY3485694873', 'RR473892711']
>>> for aValue in bunchOfValues:
...  if aValue[:2] in ['XY', 'RR']:
...      print aValue[2:]
...  else:
...      print aValue
885442554
TY3485694873
473892711
particularly useful to avoid extensive if, elif, else statements
AmyKlug
...  else:
...      print aValue
885442554
TY3485694873
473892711
True! Here is the code:
>>> import arcpy
>>> fc = r"H:/Test.gdb/XY_1_1"
>>> for row in cursor:
...     row = row[0]
...     if row[:2] in prefix:
...     else:
...         print "Name is up-to-date"
Thanks again
