Relative Field Values in For Loop
1362
03-15-2012 01:45 PM
TomGiles
My issue is trying to retrieve field values inside a for loop:
#userFile - type FeatureLayer
userFile = arcpy.GetParameterAsText(0)
#user selects field from userFile - type Field "obtained from [userFile]"
userField = arcpy.GetParameterAsText(1)
#start cursor
rows = = arcpy.SearchCursor(userFile)
#inside loop, report all values of field [userField]
for row in rows:
        arcpy.AddMessage("Analyzing zone " + row.userField)
Python wants userField to be a hard coded value for the field. It won't accept it as a variable set by the user. Any way I can accomplish this?
Cheers
Tom
MathewCoyle
Honored Contributor
row.getValue(variable)
TomGiles
Thanks Mathew - I knew it was too easy.
DanPatterson_Retired
Also Tom, you have == in the searchcursor line which won't work ... which I see you have now fixed
