Reg : Mosaic Dataset Copy from one gdb to another
6224
11
12-13-2012 09:26 AM
VikramS
All,
What tool should i use to transfer Mosaic Dataset from one file geodatabase to another fiel geodatabase .
I tried using arcpy.Copy_Management(in,out,"MOsaicDataset") . It is breaking the link  ..
Can you please help me out
Thanks
JakeSkinner
Esri Esteemed Contributor
I was able to reproduce the same behavior with ArcGIS Desktop 10 SP 5.  This appears to be resolved at 10.1.  I would recommend following up with Tech Support so they can log this bug, attach your customer information to the bug, and offer any workarounds.
JakeSkinner
Hi Vikram,
The Copy_management will work.  When you initially loaded the rasters into the mosaic dataset, did you use UNC paths?  If not, and you copy the mosaic dataset to another server, the mosaic dataset will not be able to find the rasters.
You can repair the mosaic dataset paths using the Repair Mosaic Dataset Paths tool and specify a UNC path.
VikramS
Hi Vikram,
Hello Jake ,
If I use like below
path = r"\\some.com\world\AppsData\Test\Test1\test.gdb\Test_2010_NC"
arcpy.env.workspace = r"\\some.com\world\AppsData\Source\Test_2010.gdb"
arcpy.Copy_management("Test_2010_NC",path,"MosaicDataset")
I am not able to see the mosaic dataset . I can see boundary feature class and log table in the destination geodatabase ..
Can you let me know whats the problem here . Thanks for the help
JakeSkinner
Right-click on your mosaic dataset > Modify > Repair.  Can you send a screen shot of this?
VikramS
Hi Jake ,
I dunn know whether I can send snapshot . But my source mosaic datasets having UNC Path .. I dunno whats the problem when I use the Copy Tool
VikramS
Hi Jake ,
[ATTACH=CONFIG]19920[/ATTACH]
Thats the output I am getting after running the Copy Tool . I didn't complete the whole Copy Tool Process as it started copying the source data into the destination
Suppose my Source data was in C:\Test\Test1\Test2\Images
If my destination gdb is in D:\temp . Then IT starts creating Folder Test1\Test2\Images (same as source) . Starts copying the images as well ..
VikramS
Hi Jake ,
[ATTACH=CONFIG]19921[/ATTACH]
JakeSkinner
What version of ArcGIS Desktop (including Service Packs) are you using?
VikramS
ARcGIS 10 SP 4
VikramS
ARcGIS 10 SP 4
If i Copy and Paste from ArcCatalog it works perfectly fine .. Is this an issue with geoprocessing tool ?
