Reformating data in a feature class/table
4408
12-16-2015 10:03 AM
benberman
I received a feature class that is currently in the format, illustrated below..
AREAPOPUNDER20POPOVER20POPOVER50
TAMPA1000
TAMPA2000
MIAMI500
MIAMI1000
MIAMI3000
MONTREAL4000
MONTREAL5000
I would be needing to re-format this feature class to:
TAMPA10002000
MIAMI50010003000
MONTREAL40005000
If anyone could recommened a script or a tool that would help reformat, that would be really helpful
thanks in advance.
DarrenWiens2
Hmmm... it works for me. Use MAX as the statistic type for each of the pop fields and AREA (the city names) for the case field. MAX should work regardless of whether it's a text or numerical field.
If that doesn't work, how does it not work? Error, blank output, wrong output?
1.)
2.)
3.)
WesMiller
DarrenWiens2
Summary Statistics, using AREA as case field and the other fields as statistics fields should do the trick.
benberman
Does not work. What statistic type would you assign to the other fields, anyway?
DarrenWiens2
1.)
2.)
3.)
benberman
Darren, changing the type to MAX does work. Thank you so much.
