Reclass python script not working
7164
12
08-14-2012 10:47 AM
JenniferDick
I'm trying to reclass a vector field that has values from 1 to 7. I would like to reclass these values to 1's & 2's. For example:
if the value is 1 reclass it to 2
if the value is 2 reclass it to 2
if the value is 3 reclass it to 1
and so on.
Here is my script, but it is not working...any thoughts?
def Reclass( !Value! 😞
  if ( !Value! = 1):
    return 2
  if ( !Value! = 2):
    return 2
  if ( !Value! = 3):
    return1
  if ( !Value! = 4):
    return 1
  if ( !Value! = 5):
    return 1
  if ( !Value! = 6):
    return 1
  if ( !Value! = 7):
    return 1
reclass( !Value! )
BruceBacia
This worked going integer to integer.  It may be the float vs. integer problem that's hanging it up ?
JenniferDick
Thanks for all the comments. I have the calculation working now. It was the Float and Integer fields causing the problem.
DanielAmrine
What about going from text to float?
I am trying to do reclass based on a text value to calcualte a buffer distance....
def Reclass(!DRILLTYPE!)
  if DRILLTYPE = U
    return 1177.5
  elif DRILLTYPE = V
    return 744.9
  elif DRILLTYPE = D
    return 744.9
  elif DRILLTYPE = H
    return 1053.4
This is what i put into the codeblock but it keeps giving me the parse syntax error mentioned above. Do I need to reclass the tex into numbers first?
Thanks!
Dan
