Receiving runtime error start edit session
4118
10-31-2013 08:32 AM
deleted-user-YRT0kQfQs2l6
Not sure why this is throwing an error.
    ## Get un-processed features from XYAttachments_insp     GUID_Lst = [row[0] for row in arcpy.da.SearchCursor(JU_Src,Srch_Fld)]     UGuid = set(GUID_Lst)     print UGuid     edit = arcpy.da.Editor(Wrksp)      for GUID in UGuid:         edit.startOperation()         edit.startEditing(True,True)         GSel = "GOSYNC.DBO.Att_Join_Tmp.wm_ElementGUID = GOSYNC.DBO.XYAttachments_insp.wm_ElementGUID AND GOSYNC.DBO.XYAttachments_insp.wm_ElementGUID =" + "'"+str(GUID)+"'"         arcpy.MakeQueryTable_management("'Database Connections\\GOSYNC_GOSYNC.sde\\GOSYNC.DBO.Joint_Use_Insp\\GOSYNC.DBO.Att_Join_Tmp';\         'Database Connections\\GOSYNC_GOSYNC.sde\\GOSYNC.DBO.Joint_Use_Insp\\GOSYNC.DBO.XYAttachments_insp'", "QryCnt", "USE_KEY_FIELDS",\          "GOSYNC.DBO.Att_Join_Tmp.OBJECTID", "GOSYNC.DBO.XYAttachments_insp.wm_ElementGUID #; GOSYNC.DBO.Att_Join_Tmp.wm_ElementGUID #;GOSYNC.DBO.Att_Join_Tmp.Attachment_ID #",\          GSel)         IDCnt = int(arcpy.GetCount_management("QryCnt").getOutput(0)) + 1         print IDCnt         WH_Clause = "\"wm_ElementGUID\" = '"+ GUID+"'"         with arcpy.da.UpdateCursor(JU_Src,[Upd_Fld],WH_Clause) as UpdCrsr:             for Urow in UpdCrsr:                 ATT_ID = str(GUID) + "_A"+str(IDCnt)                 print ATT_ID                 print Urow                 Urow[0] = ATT_ID                 UpdCrsr.updateRow(Urow)                 IDCnt = IDCnt + 1             edit.stopOperation()             edit.stopEditing(True)         arcpy.Delete_management("QryCnt")
Any help would be appreciated.
I found the solution
    GUID_Lst = [row[0] for row in arcpy.da.SearchCursor(JU_Src,Srch_Fld)]     UGuid = set(GUID_Lst)     print UGuid      for GUID in UGuid:         GSel = "GOSYNC.DBO.Att_Join_Tmp.wm_ElementGUID = GOSYNC.DBO.XYAttachments_insp.wm_ElementGUID AND GOSYNC.DBO.XYAttachments_insp.wm_ElementGUID =" + "'"+str(GUID)+"'"         arcpy.MakeQueryTable_management("'Database Connections\\GOSYNC_GOSYNC.sde\\GOSYNC.DBO.Joint_Use_Insp\\GOSYNC.DBO.Att_Join_Tmp';\         'Database Connections\\GOSYNC_GOSYNC.sde\\GOSYNC.DBO.Joint_Use_Insp\\GOSYNC.DBO.XYAttachments_insp'", "QryCnt", "USE_KEY_FIELDS",\          "GOSYNC.DBO.Att_Join_Tmp.OBJECTID", "GOSYNC.DBO.XYAttachments_insp.wm_ElementGUID #; GOSYNC.DBO.Att_Join_Tmp.wm_ElementGUID #;GOSYNC.DBO.Att_Join_Tmp.Attachment_ID #",\          GSel)         IDCnt = int(arcpy.GetCount_management("QryCnt").getOutput(0)) + 1         print IDCnt         WH_Clause = "\"wm_ElementGUID\" = '"+ GUID+"'"         with arcpy.da.Editor(Wrksp):             with arcpy.da.UpdateCursor(JU_Src,[Upd_Fld],WH_Clause) as UpdCrsr:                 for Urow in UpdCrsr:                     ATT_ID = str(GUID) + "_A"+str(IDCnt)                     print ATT_ID                     print Urow                     Urow[0] = ATT_ID                     UpdCrsr.updateRow(Urow)                     IDCnt = IDCnt + 1          arcpy.Delete_management("QryCnt")
