Re: UnicodeDecodeError: utf8 codec can't decode byte invalid continuation byte
77879
20
05-17-2015 02:57 AM
Yaron_YosefCohen
From: SearchCursor directory and subdirectories using python
I run the code and py fined layers with YEUD=20
but i also get en error:
  File "C:\Users\yaron.KAYAMOT\Desktop\geonet.PY", line 11, in <module>
    for row in rows:
UnicodeDecodeError: 'utf8' codec can't decode byte 0xe7 in position 23: invalid continuation byte
i use files and folders names Right to left- how can i solve this issue please?
curtvprice
This line is a replacement for line 08. I was hoping someone that knows more about international characters will chime in!
Yaron_YosefCohen
i get an error:
  File "C:\Users\yaron.KAYAMOT\Desktop\python.py", line 9, in <module>
    shp.decode('iso-8859-1').encode('utf-8')
NameError: name 'shp' is not defined
curtvprice
Sorry:
shp = (os.path.join(root, filename)).decode('iso-8859-1').encode("utf-8")
Yaron_YosefCohen
an error:
IOError: <unprintable IOError object>
i think now there no unicode error -but there problem else
curtvprice
I think you're going to have to find someone that has a better handle on this unicode stuff. I added some tags that maybe will attract some help.
RebeccaStrauch__GISP
YYC,
I'm not familiar with unicode, but I did test you code with a some of my own shape files against a field ACRES (format DOUBLE) and it worded without an error.  What is the format of your "YEUD" field?  The code I used (changed to match my data):
import os
import fnmatch
import arcpy
rootPath = r"D:\Project\layers"
pattern = 'lake*.shp'
for root, dirs, files in os.walk(rootPath):
    for filename in fnmatch.filter(files, pattern):
        shp = os.path.join(root, filename)
        if arcpy.ListFields(shp, "ACRES"):
            print("{} has ACRES field".format(shp))
            with arcpy.da.SearchCursor(shp, ["ACRES"]) as rows:
                for row in rows:
                    if row[0] > 300000:
                        print("{} has a record with ACRES > 3000000".format(shp))
                        break
My results were:
D:\Project\layers\lakes.shp has ACRES field
D:\Project\layers\lakes.shp has a record with ACRES > 3000000
D:\Project\layers\lake_10.shp has ACRES field
D:\Project\layers\lake_11.shp has ACRES field
curtvprice
YYC's issue is not my scripting -- he's working with international characters in the path names, which are way out of my expertise!!  The YEUD field is an integer (in the international language of IEEE representations) so there is not a problem there.
YYC, I'm afraid think you may need to ask for tech support from your local Esri affiliate or user groups on this one.
Yaron_YosefCohen
Rebecca,
"YEUD" field type is Double
curtvprice
As I said YEUD is not the issue, it's the feature class pathname (shp) using those funky right-to-left characters.
Yaron_YosefCohen
i think you right
