Re: UnicodeDecodeError: utf8 codec can't decode byte invalid continuation byte
77934
20
05-17-2015 02:57 AM
Yaron_YosefCohen
From: SearchCursor directory and subdirectories using python
I run the code and py fined layers with YEUD=20
but i also get en error:
  File "C:\Users\yaron.KAYAMOT\Desktop\geonet.PY", line 11, in <module>
    for row in rows:
UnicodeDecodeError: 'utf8' codec can't decode byte 0xe7 in position 23: invalid continuation byte
i use files and folders names Right to left- how can i solve this issue please?
curtvprice
I started a new thread on this issue.
These links may help, but I have no experience with international codesets -- perhaps you need to encode your path strings before parsing them, or do something with locale - or somehow change your codec to Latin-1?
UnicodeDecodeError: 'ascii' codec can't decode byte 0xe9 in position 6: ordinal not in range(128)
python - UnicodeDecodeError, invalid continuation byte - Stack Overflow
RebeccaStrauch__GISP
Check to make sure your indentations are correct and : are placed where they should be, etc.  I've received similar errors  when I've had just a typo several lines up.  i know this question was spun off another with coding suggestions., so maybe  something was missed when merging with your code.  Errors can be deceiving sometimes, so worth a syntax check.
Yaron_YosefCohen
Hi Rebecca,
i run the code and there where no identations error-else python would not  run the code
YYC - It may be helpful for others if you post the full code where you are getting an error.  The post this was spun off of shows Curtis' suggestion, but not you final code.
Yaron_YosefCohen
Hi Rebecca,
this is the code:
import os
import fnmatch
import arcpy
rootPath = r"C:\Project\layers"
pattern = 'mig*.shp'
for root, dirs, files in os.walk(rootPath):
    for filename in fnmatch.filter(files, pattern):
        shp = os.path.join(root, filename)
        if arcpy.ListFields(shp, "YEUD"):
            print("{} has YEUD field".format(shp))
            with arcpy.da.SearchCursor(shp, ["YEUD"]) as rows:
                for row in rows:
                    if row[0] == 20:
                        print("{} has a record with YEUD = 20".format(shp))
                        break
curtvprice
Based on this:
character encoding - Python: Converting from ISO-8859-1/latin1 to UTF-8 - Stack Overflow
I'm wondering if you may be able to fix this by doing a quick conversion to utf-8:
shp = (os.path.join(root, filename)).encode("utf-8")
Yaron_YosefCohen
i get an error :
  File "C:\Users\yaron.KAYAMOT\Desktop\python.py", line 9, in <module>
UnicodeDecodeError: 'ascii' codec can't decode byte 0xe7 in position 23: ordinal not in range(128)
curtvprice
Sorry, I didn't read the post I linked carefully enough. In this example iso-8859-1 is the codes your paths are in.
shp.decode('iso-8859-1').encode('utf-8')
I'm going to link the post again because it has lots of really useful information about unicode, latin1, utf-8...
Yaron_YosefCohen
where to  insert this route?
