Re: Dynamic segmentation with respect to a control factor Additional Requirements
19316
56
05-08-2015 08:06 AM
ChukwuemekaEzeiruaku
I was able to figure out the error from earlier, but i have one more request.
If i have other fields in the table i want to also show on the out_table for example see table below:
DataUniqueIDItem IDBegin EndInput Table
Observation1555100001
555100105
555100217
555100345
555100435
Observation2600200103
600200226
600200335
DataUniqueIDBegin EndItem IDOutput Table
Observation1555011001
555131001; 1002
555341001; 1002; 1004
555451001; 1002; 1003; 1004
555571002
Observation2600022001; 2002
600232001; 2002
600352002; 2003
600562003
Is there a way to differentiate between records that are within a certain range(with UniqueID) as shown in the table above, plus have other fields for that range (with same uniqueID) in the output table?
I am really grateful for your help thus far guys, Thanks.
i saw the decimal places too but the ItemIDs should be a Long data type though.
i saw the decimal places too but the ItemIDs should be Integer (Long) data type though.
If its ok with you we can take the dates out of the script, i tried modifying your codes, the run was successful but the output has just one UniqueID and duplicate records of the only uniqueID
i think i know why the last script failed;
i noticed that from the segment, there are overlapping records for which one record/row do have a date and the other didn't... i think that was why we i had the error below(image)Capture.JPG...
is there a line(syntax) i can add to it that'll which will add both the date and the null values for a segment?
thanks Blake for the codes, i was able to get one of the previous script to work(see below)
is there a way to include a loop statement in an attempt to eliminate duplicate records?
  1. def main():
  2.     import arcpy
  3.     import os
  4.
  5.     # Local variables
  6.     sourcegdb = r"N:\TechTemp\BlakeT\Work\TEMP.gdb"
  7.     table_in = os.path.join(sourcegdb, "SegmentSequence"
  8.
  9.     # Create output table
  10.     arcpy.CreateTable_management(sourcegdb, "SegmentSequence_output"
  11.     table_out = os.path.join(sourcegdb, "SegmentSequence_output"
  12.     arcpy.AddField_management(table_out, "UniqueID", "SHORT"
  13.     arcpy.AddField_management(table_out, "Begin", "SHORT"
  14.     arcpy.AddField_management(table_out, "End", "SHORT"
  15.     arcpy.AddField_management(table_out, "SegmentItems", "TEXT", field_length=255
  16.
  17.     # Identify observation groups
  18.     sqlprefix = "DISTINCT UniqueID"
  19.     sqlpostfix = "ORDER BY UniqueID"
  20.     observations = tuple(uid[0] for uid in arcpy.da.SearchCursor(table_in, ["UniqueID"], sql_clause=(sqlprefix, sqlpostfix)))
  21.
  22.     fields_out = ["UniqueID", "Begin", "End", "SegmentItems"
  23.     with arcpy.da.InsertCursor(table_out, fields_out) as i_cursor:
  24.         for obsv in observations:
  25.             # Read item and (begin, end) into dictionary
  26.             fields_in = ["ItemID", "Begin", "End"
  27.             where_clause = "UniqueID = {}".format(obsv)
  28.             itemsdict = {r[0]:(r[1], r[2]) for r in arcpy.da.SearchCursor(table_in, fields_in, where_clause)}
  29.
  30.             # Identify segments
  31.             allsegments = [i[0] for i in itemsdict.values()] + [i[1] for i in itemsdict.values()]
  32.             segments = tuple(sorted(set(allsegments)))
  33.             del allsegments
  34.
  35.             # Identify items in each segment
  36.             for enum, seg in enumerate(segments):
  37.                 try
  38.                     begin = seg
  39.                     end = segments[enum + 1
  40.                 except IndexError:
  41.                     break
  42.                 seg_items = [k for k, v in itemsdict.items() if v[0] <= begin and v[1] >= end]
  43.
  44.                 # Write segment items to output table
  45.                 row = (obsv, begin, end, str(seg_items).strip('[]'))
  46.                 i_cursor.insertRow(row)
  47.
  48.
  49. if __name__ == '__main__'
  50.     main()
BlakeTerhune
I don't get the duplicates when I run the script, so I can't modify the code unless I know what the problem is. Maybe this would be a good time for you to jump into the Python pool and try modifying the code yourself. Use my comments (and the other code posted by Xander) and look up what some of the functions are doing. Empower yourself to solve your own problems and develop new solutions. I don't mean for that to sound harsh, I'm just trying to help.
Thanks a lot Blake for your assistance thus far, i really appreciate every help.
But, I just have one more question/request hope you can help still....
I'm trying to make a script tool for the script for just the input and output parameters and i  came up with:
After making the script tool i get the following error:
BlakeTerhune
Looks like it can't find SegmentSequence_output12 in HT_Overlap_Inscope.gdb
Did you verify that feature class is there and that it doesn't have a lock?
Thanks for putting words out there for me not been able to view attachments,and i can now view attachments.
Oh it is supposed to create a GDB table from the user input from user input to also a user output as shown in the script (see picture above)
