raw_input in Select_analysis?
1109
03-30-2011 10:03 AM
RyanCooper
I'm working on a simple suitability analysis project for my GIS programming class wherein raw_inputs iare used to define part of the where_clause in Select_analysis. Here is what I have so far:
import arcpy
arcpy.env.workspace=r"I:\GIS\Test.mdb"
EL1=raw_input('Enter name of elementary school')
arcpy.Select_analysis('SchoolDistrictsElementary',r'I:\GIS\Output.mdb\school'+'_'+'EL1','[NAME]=EL1')
When I run the script, I get the following error:
General function failure [SchoolDistrictsElementary]
Too few parameters. Expected 1.
Failed to execute (Select).
I've tried everything I could think of, although my Python-fu is pretty weak. Nonetheless, this seems like on of those cases when the answer is right under my nose. Any thoughts on how to fix this issue? Thanks!
StevenArebalo
import arcpy
outFeatureClass='I:\GIS\Output.mdb\school_'+EL1
whereString='[NAME]="'+EL1+'"'
arcpy.Select_analysis('SchoolDistrictsElementary',outFeatureClass,whereString)
In your original code, the variable EL1 was read as a string instead of it's value in your WHERE clause. I haven't ran the code, but this should work. Hope this helps.
edited due to misreading OP
RyanCooper
Thanks for your reply. I couldn't quite get that to work. It would return an error that there was a missing operator for:
whereString='I:\GIS\Output.mdb\school_'+EL1+',[NAME]="'+EL1+'"'
Anyway, I adjusted my project a little bit so it's not so important that I have this element to it. Nonetheless, thank you again for your help!
