help with text element
2296
5
03-31-2011 05:57 AM
FrankVignati
updating a text element in an mxd is not working for me
ArcGIS 10 - 10.1.2800
there is a text string element in the mxd "SHEET   3002" that i want to change based on a variable
this was tested on an mxd that only has this text element in it and nothing else
this is the code to change the text element it that is not working:
import arcpy
import arcpy.mapping
MXD = arcpy.mapping.MapDocument("CURRENT")
for SheetNum in arcpy.mapping.ListLayoutElements(MXD, "TEXT_ELEMENT", "SHEET*"):
    SheetNum.text = "SHEET   7001"
if the code is:
import arcpy
   if SheetNum.type == "TEXT_ELEMENT":
still nothing happens
if i try:
SheetNum = arcpy.mapping.ListLayoutElements(MXD, "TEXT_ELEMENT", "SHEET*")[0]
it returns:
Runtime error <type 'exceptions.IndexError'>: list index out of range
what is wrong with this?
JakeSkinner
Esri Esteemed Contributor
You will need to add 'arcpy.RefreshActiveView()' at the end of your code.  Try the following:
import arcpy
mxd = arcpy.mapping.MapDocument(r"CURRENT")
for elm in arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT", "*SHEET*"):
    if elm.type == "TEXT_ELEMENT":
        elm.text = "SHEET 7001"
Note:  I also had to add an '*' in front of SHEET for the wildcard to work correctly.
FrankVignati
import arcpy
if i add an asterisk before SHEET than every text element gets selected, please see picture
is there a way to put a Like operator for python?
for SheetNum in arcpy.mapping.ListLayoutElements(IMXD, "TEXT_ELEMENT", "*SHEET*"):
    if SheetNum.text LIKE "SHEET*"
        SheetNum.text = "SHEET <Some Number>"
edit:
i thought maybe the element could be captured by it's location, but this also returns nothing
...     if SheetNum.text == "SHEET   2156":
...         print SheetNum.elementPositionX
38.926
...     if SheetNum.elementPositionX == 38.926:
...         print SheetNum.text
...     if SheetNum.elementPositionX == "38.926":
JakeSkinner
This looks to be a bug with the ListLayoutElements function.  The "SHEET*" wildcard should be returning the text elements that begin with "SHEET".  I would recommend reporting this to tech support so they can document this bug.  I haven't been able to find a workaround yet, but I'll keep looking a little bit longer.
FrankVignati
thank you for your time, any help would be greatly appreciated
i tried adding it as a title intstead, is there a way to change a title in arcpy?
FrankVignati
this is clunky but it works, the text element was set to SHEET  0000 on the mxd
then ran this code:
## Set the Sheet Number
Sheet = arcpy.GetParameterAsText(0) # 7001 for example
for SheetNum in arcpy.mapping.ListLayoutElements(IMXD, "TEXT_ELEMENT"):
   if SheetNum.text == "SHEET   0000":
       SheetNum.text = r"SHEET   %s"%(Sheet)
## Export the map to PDF
arcpy.mapping.ExportToPDF(IMXD, Output)
## Set the Sheet Number back
   if SheetNum.text == r"SHEET   %s"%(Sheet):
       SheetNum.text = "SHEET   0000"
