Raster Domain python script change output location
5574
14
11-27-2018 02:12 PM
Jacques-AlexandreGadoury
I have a folder tree with many other folders in it containing many images. I have managed to make a script that will parse through the entire folder and find every image in it. It then uses raster domain to create a polygon shapefile of every footprint for each image.
The issue I am having is I need to have those footprints exported to a single folder named "index". The current script always exports the footprints to the same folder the image is located in. How can I change my script to export the raster domain footprints to the "index" folder instead of them being exported to the folder containing the imagery?
Here is my script:
import arcpy
import os
workspace = r”D:\Folder\Test”
outFile = r”D:\Folder\Index”
rasters = []
arcpy.CheckOutExtension(“3D”)
print ‘Processing’
for dirpath, dirnames, filenames, in arcpy.da.Walk(workspace, topdown=True, datatype=”RasterDataset”):
                for filename in filenames:
                                rasters.append(os.path.join(dirpath, filename))
for raster in rasters:
                outGeom = “POLYGON”
                outPoly = raster[:-4]+”.shp”
                arcpy.RasterDomain_3d(raster, outPoly, outGeom)
print rasters
print ‘Completed’
I'm pretty sure the answer lies with changing the "outPoly" parameter but anything I have tried resulted in an error. Any help would be much appreciated.
Thank you for your time.
DanPatterson_Retired
If you are using ArcGIS pro then be aware...
Shapefiles cannot be added to the project Databases folder but must be stored in the project folder or a folder connection.
Shapefiles in ArcGIS Pro—Shapefiles | ArcGIS Desktop
I am on ArcGIS 10.4.  But it is indeed useful to know that about ArcPro for future reference.
JakeSkinner
Esri Esteemed Contributor
Try the following:
    outGeom = "POLYGON"
    outPoly = os.path.basename(raster)[:-4]+".shp"
    arcpy.RasterDomain_3d(raster, os.path.join(outFile, outPoly), outGeom)
Beautiful Jake,
That seems to have worked. I'm guessing that os.path.basename(raster) stripped the path that was appended in the rasters =[] list? Anyways I think this should do. Thank you for your help. I'll just action this as correct as it did complete what I set out for.
JakeSkinner
Yes, the os.path.basename simply took the file name rather than the entire path.
