Ranking Fields
4174
7
06-08-2011 07:37 PM
chriss_
Hi!
What I am looking for is giving the FieldA a Rank depending on the values in FieldB. I would like to end up with sth. like this. Can i do this easy in the field calculator?
Rank     orig. Value
1           5
2           7
3           14
4            23
in python i did it like this:
import arcpy, numpy, os
from arcpy import env
ShapeName=arcpy.GetParameterAsText(0)
Field=arcpy.GetParameterAsText(1)
RankField=arcpy.GetParameterAsText(2)
rows = arcpy.SearchCursor(ShapeName)
d=[]
for row in rows :
    FieldValue=row.getValue(Field)
    d.append(FieldValue)
d.sort()
arcpy.AddMessage(d)
del rows
rows2 = arcpy.UpdateCursor(ShapeName,"","",RankField,"")
row2= rows2.next()
while row2:
    x=0
    for i in d:
        y=d
        if row2.getValue(Field)==y:
            rank2=d.index(y)
            rank=rank2+1
            row2.setValue(RankField, rank)
            rows2.updateRow(row2)
        x=x+1
    row2 = rows2.next()
del rows2
Thanks for any help
TerrySilveus
put this in the code block
 def returnvalue(y):
    if  y >= 0 and y <= 3:
       x = 1
    elif  y > 3 and y <= 6:
       x = 2
    else:
       x = 3
    return x
and in the = box put
returnvalue( !fieldnametocheck! )
substitute your values for ranking and return values as you see fit
chriss_
Hi!
Thanks for ur reply!
BUT that is not what i am looking for.  I speak about several hundred rows. I m looking for some command. Like "rankdata" or sth. like this. I wonder that i didnt find any other entry in the forum. For me it looks odd that this very standard function is not available.
cu
Chris
MathewCoyle
Honored Contributor
I'm not 100% sure what exactly it is you are trying to do, but this will fill in a "Rank" field based on another field of values sorted from lowest to highest.
print "Starting script"
import arcpy
arcpy.env.workspace = r"C:\GIS\Default.gdb"
Field = "<YOUR FIELD>"
currRank = 0
lastRank = 0
lastVal = None
rows = arcpy.UpdateCursor("<YOUR FC>", "", "", "<YOUR FIELD>,RANK", "<YOUR FIELD> A")
print "Starting loop"
for row in rows:
    currVal = row.getValue(Field)
    if currVal != lastVal:
        currRank += 1
        row.Rank = currRank
    elif currVal == lastVal:
        row.Rank = currRank
    else:
        print "Unexpected occurance"
    lastVal = currVal
    rows.updateRow(row)
del rows
print "Done"
TerrySilveus
Hi!
cu
Chris
I see.  Sorry, I misunderstood your question and didn't pay close attention to your code.
BenjaminSperry1
This worked for me
import arcpy
rank = 1
fc = <the feature class you want to rank>
sqlclause = sql_clause=(None, 'ORDER BY <Ranking Field> DESC')
with arcpy.da.UpdateCursor(fc,'<the rank field>',sql_clause=sqlclause) as cursor:
    for row in cursor:
        row[1] = rank
        cursor.updateRow(row)
        rank = rank + 1
del cursor
The idea is that I sort the featureclass based on my ranking criteria and then just add 1 to the rank for each loop.
This assumes that you are basing you ranking on a single field.
Instead of DESC which is decending order you could use ASC which is ascending order.
This forum post helped: arcgis 10.1 - Is it possible to sort an arcpy.da.UpdateCursor()? - Geographic Information Systems St...
JoshuaBixby
MVP Esteemed Contributor
The code as written represents an ordinal numbering of the table based on a sorting field, it would only represent a ranking if the sorting field contains no duplicate values.  Although the OP's example showed uniqueness in the value field, and the provided code snippet works for that example, it is quite common to have duplicate values in a ranking field.  Mathew Coyle‌'s code, although using older/original cursors (that is all that was available at the time), does address ranking more generally.
BenjaminSperry1
I had missed that, thank you very much for pointing it out.
