Raster Calculator Python
14576
11-28-2011 03:11 AM
JohanL
Hi Everyone,
I am trying to implement a simple raster calculator within my python script as the following
arcpy.gp.RasterCalculator_sa("\"%Temp4%\"/2", Temp2)
But I am receiving the following error in python
"Warning (from warnings module):
  File "<string>", line 1
SyntaxWarning: import * only allowed at module level
  File "F:\test.py", line 75, in <module>
  File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\geoprocessing\_base.py", line 474, in <lambda>
    return lambda *args: val(*gp_fixargs(args))
ExecuteError: ERROR 000539: Error running expression: rcexec() <type 'exceptions.TypeError'>: unsupported operand type(s) for /: 'str' and 'int'
Failed to execute (RasterCalculator)."
I am using arcpy.CheckOutExtension("spatial") so im not sure what the first point of the error is implying!
This is really frustrating... any help would be appreciated!
Bjebn
RaphaelR
according to the help, the raster calculator is for use inside arcmap only, for calculations in python you should use mapalgebra:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//009z000000z7000000.htm
JohanL
Ah of course... i did the mistake of exporting the script from the modelbuilder and tried to modify it -  what a frustrating mistake!
JohanL
I am still having problems with map algebra... its probably an obvious mistake but I cant identify it!
Here is a part of the code im having trouble with...
import arcpy, os, sys, string
from arcpy import env
from arcpy.sa import *
arcpy.env.workspace = r'O:\DATA\test'
InputFolder = arcpy.env.workspace
Temp4 = InputFolder + '\\' + temp4
RasterList = arcpy.ListRasters()
    for RasterImage in RasterList:
    Temp4 = FocalStatistics('RasterImage', NbrRectangle (9, 9, 'CELL'), "RANGE", "DATA")
    print ('Focal Statistics')
I receive the following error
"Traceback (most recent call last):
  File "O:\test.py", line 67, in <module>
  File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\sa\Functions.py", line 4796, in FocalStatistics
    ignore_nodata)
  File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\sa\Utils.py", line 47, in swapper
    result = wrapper(*args, **kwargs)
  File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\sa\Functions.py", line 4790, in wrapper
    ignore_nodata)
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000865: Input raster: RasterImage does not exist.Failed to execute (FocalStatistics)."
It does not seem to recognize my for in loop of the RasterImage - any ideas?
RaphaelR
try removing the ' before and after RasterImage in the Temp4 = FocalStatistics()... line. It´s a variable, i think they way you´ve got it in  there it´s looking for a string
