Raster Calculator for Python Script
11635
15
06-27-2013 07:56 AM
SAC_PhySAC_Phy
I cannot get a conditional evaluation calculation to be done on two rasters.
I want an ouput raster to be created from the positive difference of two rasters (so no negative numbers)
The part of the code that isn't working
import arcpy
import os
from arcpy import env
from arcpy.sa import *
import arcgisscripting
arcpy.CheckOutExtension('Spatial')
I've tried two different ways, both failing
Method one
        arcpy.AddMessage("Creating Elevation Raster")
env.workspace = FD_addr
list = arcpy.ListRasters("*", "ALL")
elevation = Con(list[1]-list[0]>=0, list[1]-list[0],0)
elevation.save(FD_addr)
Method two
expression = "Con({}-{}>=0, {}-{},0)".format(list[1], list[0], list[1], list[0])
OR = "elevation3"
OutRaster = os.join.path(FD_addr,OR)
gp = arcgisscripting.create()
gp.SingleOutputMapAlgebra_sa(expression, OutRaster)
my list has two rasters (I've checked to make sure they are there): a DSM and a DEM, and I want to find the positive elevation difference between the two.
Any help would be appreciated! I've been stuck on this for ages.
ChrisSnyder
Honored Contributor
The inputs need to be "raster objects" to work in teh new map algebra. Try this:
import arcpy, os
arcpy.env.workspace = FD_addr
raster0 = arcpy.Raster(list[0])
raster1 = arcpy.Raster(list[1])
elevation = arcpy.sa.Con(raster1 - raster0 >= 0, raster1 - rasters0, 0)
SAC_PhySAC_Phy
import arcpy, os
While this went through without giving any error message, no raster was created (or saved?).
ChrisSnyder
Honored Contributor
Yep - on the last line try:
elevation.save("my_output")
The raster "my_output" should then be saved to the 'FD_addr' workspace.
Question though: Does 'FD_addr' point to a feature dataset within a geodatabase? Last I checked, I thought that you can't write rasters to a feature dataset (has to be directly to the GDB).
SAC_PhySAC_Phy
Tried both
my_output.save(FD_addr)
"my_output".save(FD_addr)
But again, neither worked/saved.
FD_addr is really just bad naming on my behalf. This is part of something much larger, and when I first began this, I had intended for FD_addr to be the location inside the (file) geodatabase where the feature dataset would be created..
So FD_addr points to within the geodatabase and not within the feature dataset.
Bad naming, I know...
But I have other rasters being created with FD_addr as their output address and they do indeed go to the correct spot.
RhettZufelt
MVP Notable Contributor
I don't see in the code anywhere that you are setting the variable 'FD_addr' (maybe it is above the imports somewhere?) to actually set the env.workspace.
Could try somehting like:
elevation.save("C:/output/file_gdb.gdb/elevation")      # or whatever the path/filename you want for your out raster
If this works, at least then you know it's an issue with the workspace/path being set properly.
R_
SAC_PhySAC_Phy
R_
Still didn't work 😕
I'm setting the workspace here:
(not sure how you make it so that code appears in gray?)
I feel that has to be working because the rasters being inserted into list are the rasters in that location (I double checked.)
FD_addr is set way in the beginning of the code.
MattSayler
http://forums.arcgis.com/threads/48475-Please-read-How-to-post-Python-code 😉
RhettZufelt
Still didn't work 😕
Interesting. Are you sure you hard-coded it to an "existing" FGDB? If so, what do you mean it didn't work? Didn't create the raster with your hard-coded name, created a blank raster? Error messages?
What does it report if make the modifications in red?
import arcpy, os
print "temporary: ",elevation.isTemporary
R_
Also, it looks like elevation.save(FD_addr) is telling it to save with the filename of the workspace. Workspace is normally a folder or FGDB, not a file.
It's my understanding that elevation.save() would save it in the current workspace as raster dataset "elevation".
Now that I think about it, before trying the above code, what happens if you try this (of course, make sure the FD_addr is set to a FGDB that the current user has write access to):
import arcpy, os
elevation.save()
SAC_PhySAC_Phy
It doesn't report anything.
I'm not sure how I see command line messages (I'm very new to this.) The only messages I can see are the ones I code in by arcpy.AddMessage("Message")
So the first option didn't give me any message (though I tried it with the arcpy.AddMessage() as well) and I tried elevation.save()
I have since changed it to elevation.save("elevation") because I figured it needed the name to save the raster to since the workspace was already set and knew where to save.
I assume I have writing privileges because before this I have a terrain to raster method, and the terrains are being saved to the same location as I'm trying to save this raster (FD_addr), but this is before I set the workspace. I only set the workspace because I wanted a list created with the rasters that are saved in the FD_addr location. So unless setting the workspace alters the writing privilege, I assume I can write files to that location.
I'm still at a loss. I feel like I've tried so many options and still don't know what's wrong or how to fix this. It seems as if it should work!
import arcpy, os
R_
import arcpy, os
elevation.save()
