How to get the last element of a polyline array?
1713
07-01-2013 08:40 AM
MennoNijhuis1
To my surprise, it is impossible to get the last element of an array from a polyline (which is a arcpy.arcobjects.arcobjects.Array, so not a normal Python array for which it would definitely work!).
my_array[-1]
throws this error:
Runtime error <type 'exceptions.RuntimeError'>: Array: Error in getting object from array
EDIT:
OK a rather stupid workaround I thought of myself:
my_array.getObject(len(my_array)-1)
gives:
<Point (280349.568, 311663.817, #, 162.393)>
I still wonder: why is it not possible to just use my_array[-1]
markdenil
As you point out, an arcpy.arcobjects.arcobjects.Array is not a normal Python array,
so it doesn't index nicely.
As a geometry object, however, it has a lastPoint property, which should be simple to access.
markdenil
ShaunWalbridge
You could subclass arcpy.Array to include a __getitem__ method, and then handle slicing and indexing there, if you want to be Pythonic about accessing the elements. However, Mark's solution is probably the simplest answer.
cheers,
Shaun
MennoNijhuis1
I hadn't even thought of accessing the geometry object, focussed as I was with accessing the array. This will work nicely, thanks both!
