Question about JoinField_Management??
1314
04-30-2013 05:55 AM
MichelleCouden1
Can anyone direct me to where it shows how to code for joining of two fields in the same layer. I found Join Field (Data Management) on Help desk, but the examples for python on the bottom are terrible.
ArkadiuszMatoszka
Are you want to create filed that contains joined values from two other field? If so, what you're looking for is combination of
arcpy.AddField_mangement and arcpy.CalculateField_management.
fields_to_join = ['!FIELD_NAME_1!', '!FIELD_NAME_2!'] # don't forget exclamation marks!
fc = 'C:/example.shp'
arcpy.AddField_management(fc, 'NEW_FIELD_NAME', 'TEXT')
arcpy.CalculateField_management(fc, 'NEW_FIELD_NAME', ''.join(fields_to_join), 'PYTHON')
If you want to use some separator between values from different fields change '' in:
to 'separator' i.e.:
 '_'.join(fields_to_join)
Hope it helps.
Cheers
Arek
MichelleCouden1
Hey Arek, my bad I forgot one layer is a gdb. Is this the right code for joining 2 fields in a shapefile and 2 fields in a gdb??
import arcpy, traceback
from arcpy import env
mxd = arcpy.mapping.MapDocument("CURRENT")
# Join Fields
fc1 = 'K:\TASS\4_MAPPING_DATA_SUPPORT\Traffic_Mapping\Traffic_Count_Data\2011_Counts\2011_Annual_Stations\Annual_Stations_2011.shp'
fc2 = 'K:\TASS\4_MAPPING_DATA_SUPPORT\Traffic_Mapping\Traffic_Count_Data\District_Labels_Folder\Abilene_Labels.gdb'
fields_to_join = ['!F2011_TRAF!', '!FLAG!']
arcpy.AddField_management(fc1, 'COUNT', 'TEXT')
arcpy.CalculateField_management(fc1, 'COUNT', ''.join(fields_to_join), 'PYTHON')
fields_to_join = ['!TextString!', '!TFLAG!']
arcpy.AddField_management(fc2, 'TRAFFIC', 'TEXT')
arcpy.CalculateField-management(fc2, 'TRAFFIC', ''.join(fields_to_join), 'PYTHON')
MichelleCouden1
Answered my own question on this. Has to be workspace!!
