pythonaddin xml separator = "True" issue
4410
03-17-2015 06:53 AM
BradGagliano
I am trying to have separators show on my addin toolbars of which I created through the pythonaddin assistant.  However I modify the config.xml to include separator="True" (See Below). Then rebuild the .esriaddin and when ArcMap is opened the toolbar shows up but without the separators on.
Anyone have any ideas?
     Toolbars>
          Toolbar caption="District 1 Toolbar" category="D1ToolbarAddin" id="D1Toolbar_AddIn.toolbar" showInitially="true">
               Items>
                    ComboBox refID="D1Toolbar_AddIn_Aerials.combobox" separator="true" />
                    Button refID="D1Toolbar_AddIn_Census.button" separator="true" />
                    Button refID="D1Toolbar_AddIn_Contours.button" separator="true" />
                    Button refID="D1Toolbar_AddIn_Drainage_Utility.button" separator="true" />
                    ComboBox refID="D1Toolbar_AddIn_HAtlas.combobox" separator="true" />
                    Button refID="D1Toolbar_AddIn_LandAcq.button" separator="true" />
                    Button refID="D1Toolbar_AddIn_Parcels.button" separator="true" />
                    Button refID="D1Toolbar_AddIn_PublicTransit.button" separator="true" />
                    Button refID="D1Toolbar_AddIn_Roadway.button" separator="true" />
                    ComboBox refID="D1Toolbar_AddIn_Enviorn.combobox" separator="true" />
                    Button refID="D1Toolbar_AddIn_LandUse.button" separator="true" />
                    Button refID="D1Toolbar_AddIn_TrafficSys.button" separator="true" />
               Items>
          Toolbar>
     Toolbars>
Menus>
     Menus>
ArcMap></AddIn></ESRI.Configuration>
DuncanHornby
MVP Notable Contributor
I don't think you can do it, there is nothing in the desktop help that indicates that separator is an attribute of a Button. Your question was asked over 2 years ago here. Apparently nobody in the whole of ESRI is able to answer this question...
BradGagliano
Thanks, that is hard to believe.
Thanks again!!
