Python - write new row based on comma-separated values in table column?
9160
02-28-2018 01:27 PM
AllenScully
Hopefully a simple (and fun!) Python loop question.
We have a dataset that looks like this:
ROWIDATTRB1ATTRB2ATTRB3ATTRB4
1AAABBBCCCABCD, EFGH,IKL
Where ATTRB4 often contains a comma-separated list of values.  Unfortunately we need these values as a join field in a SQL view, so the comma-separated list format output we receive needs to be changed so that there is only 1 value in the ATTRB4 column
So, what I'm working on is creating a non-normalized version of this table (actually a feature class) that will have 3 duplicate rows (duplicate rows not a problem in this case) , with identical values for ATT1-3 but with the ATT4 value being a single one of the comma-separated list values:
1AAABBBCCCABCD
2AAABBBCCCEFGH
3AAABBBCCCIJKL
I believe I need to get the comma-separated ATTRB4 column into a list, and loop through it, but am not quite sure how to wrap my head around the code here.
Allen
PS the comma-separated list values are the result of GeoEvent service (v 10.5.1) that uses a GeoFence and GeoTagger to identify points in certain areas and add the GeoFence name to the output - so when a point is within multiple areas, the multi-value list is result.  If anyone happens to know a way to force GeoEvent to output in the format shown in the 2nd table, that would work too.
JamesMacKay3
Something like this should do it:
fieldList = [ "ATTRB1", "ATTRB2", "ATTRB3", "ATTRB4" ]
with arcpy.da.InsertCursor(targetTable, fieldList) as insertCursor:
    with arcpy.da.SearchCursor(sourceTable, fieldList) as ‍‍searchCursor:
        for row in searchCursor:
            for attrbPart in row[3].split(","):
                insertCursor.insertRow(( row[0], row[1], row[2], attrbPart ))
I would throw in some null testing, empty string testing, error handling, etc.
JamesMacKay3
AllenScully
James this is perfect -
Works like a charm almost 'out of the box'.  Many thanks
