Python Tutorial
2568
7
06-18-2014 07:14 AM
bidemiadejumo
Does anybody know where i can find a comprehensive python interactive tutorial?
IanMurray
Honored Contributor
Have you tried Code Academy?  I found them pretty useful while I was learning python alongside the class I was taking.
"Comprehensive" is somewhat subjective, since I doubt almost any python user uses all of python functionality, and the amount of modules that can be added in is quite high.  Their tutorials will get you a good basic understanding of python syntax, methods, strcuture, etc.
Luke_Pinner
MVP Regular Contributor
I like http://learnpythonthehardway.org (and it's not as hard as the title suggests)
AlexanderNohe1
Honored Contributor
The following blog may be a good start:
Seven easy ways to start learning Python and ArcPy
Seven easy ways to start learning Python and ArcPy | Support Services Blog
This offers several different options for you to learn Python so if you learn better one way or another, those options are available to you.
JoshuaChan
for some reason clicking on that link only goes to the Support Centre's home page.
I had to copy / paste this "http://blogs.esri.com/esri/supportcenter/2014/03/26/8-easy-ways-learning-python-arcpy/" into the browser for it to get to the correct site.
DuncanHornby
MVP Notable Contributor
I know you requested an interactive tutorial but I would highly recommend the book Python - Scripting for ArcGIS which is published by ESRI. It starts with the basics and then leads into using Python and ArcPy so very desktop focused. I find I regularly check this book, especially when I need to fiddle around with geometries as I can never remember the syntax!
DanPatterson_Retired
You may want to examine code samples posted by Esri ie
ArcPy Café | Get all your ArcGIS Python Recipes here!
PeterVersteeg
I know its very basis but i like how he teach this stuf and its free
Python Programming Tutorial - 1 - Installing Python - YouTube
